Kioti CK2610 drawbar
/ Kioti CK2610 drawbar #1
pmhowe
North west North Carolina
Kioti CK2610
The drawbar on my new CK 2610 has a 1 1/8" diameter hole. This is far too large for the standard Category 1 pin. In fact, the largest hitch-pin I could find on the internet (Messicks, Tractor Supply Company, etc.) was 1" diameter. So, some questions:
1. Is this a standard size hole?
2. Can I get a sleeve to reduce the hole size to accept a 3/4" pin?
3. What do you use when you want to pull something with the drawbar?
Thanks for the help.
Phil
/ Kioti CK2610 drawbar #2
I just use a shackle and a chain.....
/ Kioti CK2610 drawbar #4
You dont need a 1 1/8 shackle. a 3/4" would work great. All you are doing is pulling with it.
/ Kioti CK2610 drawbar #5
Phil
When I bought my tractor (used) it did not come with a drawbar, so I improvised with an old bumper hitch bar from a car (was in the scrap pile). I use one of these when the ball would normally go...
https://www.tractorsupply.com/tsc/product/countyline-clevis-hitch-pin-24cbw002tsc
I have seen people put the ball for a trailer hitch in the end hole (not sure it will fit in 1 1/8th though).
Rancho
/ Kioti CK2610 drawbar #6
You need an oversized hole. Anytime you go across uneven ground (a road ditch, terraces, etc) you have movement between the tractor and whatever your pulling; both left and right as well as up and down. A ball hitch is, of course, the best since you have free movement in all angles, without any slop. However, at the speeds tractors operate, a considerable amount of slop is really no big deal. If you use a 3/4 inch pin in a 7/8 inch hole, you will put incredible strain on that pin if (when) you go over uneven ground.
/ Kioti CK2610 drawbar #7
The drawbar/hitch comes in handy but be aware it can interfere with a 3-point implement/attachment.
Don't ask me how I know.
/ Kioti CK2610 drawbar #9
This is the best answer so far;
Any towed implement that attaches to a drawbar with a clevis style hitch needs space to move .
Traveling across a field and the rear axle of the tractor goes thru a dip or wash with both tires the angle between the hitch and the implement will change if there is not room for the pin to float a severe strain will result and something will need to give (bend or get twisted). in the same vein the left side of the tractor goes thru a hole while the left side of the implement goes over a rock or hump the pin and clevis has to allow free movement or something will be strained, stressed or bent.
/ Kioti CK2610 drawbar #10
On road vs off road; on road / flat service you use a ball mount for towing, off road / rough terrain a pintle mount is the way to go, that larger hole in essence will act like the pintle will, it will allow for some slop and assist in preventing binding......
INSPECTION (A65579)
INSPECTION (A65579)
2014 John Deere 8345R (A64126)
2014 John Deere...
2015 Ford Explorer SUV (A64557)
2015 Ford Explorer...
2001 Ford F-550 Truck (A66408)
2001 Ford F-550...
Bobcat Pallet Forks (A64127)
Bobcat Pallet...
John Deere 6400 (A64126)
John Deere 6400...
