L3901 Hood Reinstallation
/ L3901 Hood Reinstallation #1
SuperiorLakeEffect
Houghton, MI
Kubota L3901
As per usual, I have no problem taking things apart- putting them back together again is the issue. :melodramatic:
Was chasing a coolant leak on my 14 hour old L3901 today (another rant altogether), so for better access- I removed the hood. Pretty straight forward, pop the pin out of the top of the strut, undo the bolt in the back, disconnect the headlight, and then jiggle things around and it pops right off.
Putting it back on proved a different beast altogether. After futzing with it for a bit, I decided there's no way to get the hood on the hinge with the strut still in place, attached at the bottom. Unfortunately, the bottom is buried between the fuel tank and the DPF. Getting a good angle on the pin seemed difficult, but I figured I had a reasonable shot at the two bolts holding the bracket on. Sure enough, there was some tacky grease on them like somebody had tried this before.
With the hood off, getting that bracket out was no problem. With the hood back on....
...well, a magnetic flashlight attached to the underside of the hood, a mirror, much cursing, and perhaps offering my first and possibly second born to some second rate deity later (None yet and hopefully I'm old enough this won't be an issue), I finally got the bracket back in place and bolted in.
Really, the next time this comes up I might say screw it to putting the strut back in. Turns out the grill guard makes an excellent hood prop if you put fold it back in, and those second rate deities are probably catching on to the fact there probably won't be any progeny forthcoming.
So anybody got a surefire method of reinstalling the hood or dealing with the strut that isn't such a pain in the ***?
/ L3901 Hood Reinstallation #2
I'm in the market for a L3901.
Come to think of it... I have an easy fix!
How about we trade my '02 BX2200 that is easy to get the hood off and back on for your rather new L3901? :D
/ L3901 Hood Reinstallation #3
Unless I'm not visualizing this correctly, could you have compressed the strut and tied if back to something?
Had you arrived at my 7th or 8th attempt at this with that offer, you might have had yourself a deal. :D
Hmm, that might be worth investigating next time. The strut requires more force than I can muster without some kind of lever- but it might be possible to tie it off on itself one I do get it compressed.
/ L3901 Hood Reinstallation #6
your set up is prob different than mine. i've had to replace hood when it became unattached from rear hinges. disconnect the hyd hood shocks @ the pin (i have 2) then raise the fel to top, tie a rope from the front of hood to fel & manually raise the hood all way up till shock aligns w/pin mount. tie off
reinsert hood to the rear hinges, then the shock pin as well.
raising the hood w/rope avoids having to compress the shocks that method worked well for the 2 times i've had to do it. but don't raise the fel w/the hood attached to it, just do it manually once the fel is in top position
2013 Haulotte 4527A (A57148)
2013 Haulotte...
New/Unused Landhonor Quick Attach Pallet Forks (A61166)
New/Unused...
2018 CATERPILLAR 304E2 CR EXCAVATOR (A62129)
2018 CATERPILLAR...
2011 Chevrolet Van (A61568)
2011 Chevrolet Van...
2009 Ford F-150 Pickup Truck (A61568)
2009 Ford F-150...
New/Unused Landhonor 20,000lb Electric Winch (A61166)
New/Unused...
