Found and fixed leak on new kx040-4
   / Found and fixed leak on new kx040-4 #1
Hersheyfarm
NE ky
There has been a small bleed of fluid from the depth of my new machine. I washed and sprayed it out a couple of times to make sure it wasnt left over fluid spillage from assembly. It wasnt so i went in to find it. It was a return hydraulic line at the bottom of the hydro tank between the tank and the cab. Had to take some stuff off to get to it. It was so loose i could move it with my finger tips, because thats all I could get on it because of where it was. Funny thing is its the only fitting that didnt have red inspection paint on it.
   / Found and fixed leak on new kx040-4 #2
The dealer ought to be made aware
   / Found and fixed leak on new kx040-4 #3
About have to have the skills and the tools of an aircraft mechanic to work on equipment these days. I know I lack much of the specialized line wrenches used on modern hydraulic systems. Had to make a few.
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55302)
2015 RAM 5500...
Landoll Lowboy Trailer (A55315)
Landoll Lowboy...
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A55315)
2025 Wacker Neuson...
2004 Freightliner FL60 Ambulance (A56858)
2004 Freightliner...
KENMORE 80 SERIES WASHING MACHINE (A54757)
KENMORE 80 SERIES...
