Performance
   / Performance
Was the tractor fully warmed up? My NX really stumbles when cold. Tractor runs lean. Goes away once at operating temps. This can take 15 minutes some days.
Yes it was warmed up. I’ve had this issue for a while. I’m just getting a little annoyed with it. Hoping someone would already have hade the problem and would tell me the fix without having to take it back to the dealership.
   / Performance
I’d send a video for you to watch/listen to, so you see what I’m talking about.
   / Performance #13
Have you called the service department? What was their answer to this to this?
   / Performance
I had list of issues that I told the service department about. They came and picked it up and had it 3 days. They fixed 2 issues and that was a taillight filling up with water and a battery post clamp that got to close to the battery hold down and melted. 1 for my linked pedal was stuck on and 2 the performance issues wasn’t addressed.
   / Performance #15
26 hp for any hydro is bare minimum. Mine is gear and did the same thing with a 72 inch finish mower.
   / Performance #16
Something's off, and the dealer needs to correct it, the first job I did with the 2610 was 18yds of damp loom, heavy stuff, it drove into the pile, lifted full buckets with ease, and drove to where I wanted it, as fast as I wanted it to go. HST/Link On/Med Range - I was very impressed for 26HP - Tell the dealer to set it up right......
   / Performance
I will give the dealership another chance.
Last time they took it for 3 days and they only replaced a taillight and a battery post clamp and brought it back never fixing the 2 issues.
   / Performance #18
Be sure you don’t inadvertently have a remote in the ON position. That will rob tons of power
   / Performance #20
What's your experience level with tractors? Reason I ask is there's a learning curve associated with running anything, and sometimes it just takes a bit to get familiar with the performance characteristics of your machine. I had a JD2305 I ran a 5 foot finish mower on. It was 23 HP with a hydro and it ran the mower just fine. However, it only had two speeds----low and high. I cut grass in low all the time. The dealership may have tested out your machine and didn't find anything wrong with it performance wise. They should be able to put it on a dyno to test HP output, but their fancy testing software/computer probably already does that for them.
My NX4510 has just enough power to move the tractor in high gear. Forget about using any implements or pulling something.
2016 Freightliner M2 106 Altec AM50 50ft Bucket Truck (A55852)
2016 Freightliner...
Hilti TE 2000-AVR Electric Jack Hammer (A55973)
Hilti TE 2000-AVR...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A55314)
Michelin CARGOXBIB...
2019 MDB FM180 FINISHING MOWER (A51247)
2019 MDB FM180...
2015 TROXEL 130BBL KILL TRAILER (A53843)
2015 TROXEL 130BBL...
Quick Attach EZ Axe Skid Steer Tree Shear (A53473)
Quick Attach EZ...
