What have a bought!
/ What have a bought! #1
ap121
Qld, Australia
MF 205 Industrial
Hey all, I'm new to the forum and excited to learn all about my newest purchase!
This beast came with a parcel of 80-Acres me and my partner just purchased, I have no idea what model or year it is so I'm hoping you knowledgeable people might be able to point me in the right direction!
Link
Previous owner said it wasn't your everyday MF 135 but a MF built specifically for loader use.. no idea if he was pulling my leg or not?
I've posted as many pictures as I could take as I have no idea about the machine, I'd like to give it a good service before putting it into action so is anyone able to point me in the direction of a workshop manual for it?
It's got two leaking bucket tilt rams, the lift pair seem fine. Need to figure out where to fill the hydraulic fluid.. Also has a flat tyre on the front right.. I was told I could pop on a regular 4X4 tyre as its a standard size (7.50x16 8-Ply), is this true? I did notice the original tyres say "Nylon" on them? Will any old tyre shop be able to fit this new tyre for me? Also am I able to run a slasher with this tractor? It has a massive counter balance on the back and I have no idea if it has PTO or not.. Unfortunaly the previous owner filled the counter balance with concrete so that going to take a little effort getting off..
I appreciate any and all help I can get with this! I'm eager to learn as much as possible!
/ What have a bought! #2
Looks like maybe an old MF 205 industrial? Does it have a Perkins diesel in it? A continental gas motor?
/ What have a bought! #4
Looks like he was telling you the truth ! It's an 'industrial' was set up with the loader. Should have the Perkins diesel. Should have pto and a two stage clutch, push the petal half way movement stops pto doesn't. Replace the fan belt while you're at it. Might as well get a set of front tractor tires , the loaders give them a workout !
Sounds like exciting times ! With a little love that old girl will be running years after the new tractors have given up .
Yes it's got a Perkins Diesel as it's printed on the side of the motor!
Okay so from the pictures on tractordata it sure is close to the Industrial 205 on their website, that gives me something to try and track down a workshop manual for it!
and thanks for the tip on the tyres, I've found a good looking option here: NEW 8 Ply TRACTOR TYRE 75-16 R1 WHOLESALERS 75x16 R1 Tractor 7.5-16 | eBay
I will be out on the property this weekend so I will test the two stage clutch and see if I can jam a camera in behind the counter balance to view the movement of the PTO.
Sdlanch 12'x20' High End Carport (A60463)
Sdlanch 12'x20'...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
12ft 5in Flat Bed (A61165)
12ft 5in Flat Bed...
MASSAGE CHAIR (A58214)
Striker TNB-4M Hydraulic Breaker (A60462)
Striker TNB-4M...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
