3520h Oil Filter
/ 3520h Oil Filter #1
ning
Elite Member
Northern California
Branson 3520h
Hi all. I'm looking for a local replacement for the oil filter for my Branson 3520h.
The current filter says EA00001160B (OEM filter), and I haven't been able to cross-reference it to anything else.
I found this post which appears to suggest a Baldwin B1432 or possibly Wix 51522, but I'm not sure it's correct.
What do you all use for this engine?
/ 3520h Oil Filter #2
I have the 3520CX so you should have the same motor.
I know Carquest 85381
And Napa gold 1381
work.
Both have been on mine.
/ 3520h Oil Filter #3
In a pinch the Wix 51626 works for me. It's got the same filter housing diameter and thread as the stock and is actually a bit larger (longer).
/ 3520h Oil Filter
Thoughts on oil?
I've got Rotella T6 5w-40 and Delo 15w-40 (both HD diesel oils), and the manual says 10w-40. I can go buy 10w-40 in town, but my guess is three are as good or better than the manufacturer expects.
It's typically 35-60°F here when I'm working in the winter.
/ 3520h Oil Filter #6
If you have both on hand use the 5w in the winter and 15w in the summer.. if your oil changes work out like that.
/ 3520h Oil Filter #7
I've been using 15w-40, Delo or T5. Our winter temps are similar to yours. One of my manuals says 15w40 above 20 or 30 degrees (can't remember which), and 5w-40 below. Others say 10w-40.
