Buying Advice Skid steer or 1460
/ Skid steer or 1460 #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Hey all
So my wonderful 1850 is really showing wear. Last night i foend the holes connection the rollover arm to the connecting plate elongating. Probably what will happen is nect year i will take the machine off line and tear it down and improve it bur that said i brought up adding a 1460 to the fleet. I would keep the 1850 but put more abuse on the 1460. But tHe wife asked the hard question. Why not a skid steer. I need to check with terry but i think my implements cross over but outside of that i didnt have an answer because i have never has a skid. Any experienced thoughts?
/ Skid steer or 1460 #2
I've only used skid steers on pretty level ground. Though i did get a bit forward on the crown of a hill, and pulled it back up with my full sized bronco. They're fast and pivot wonderfully. Never used one with track though.
/ Skid steer or 1460 #3
I have an 1850 and a small skidsteer. Often rent larger ones when needed. Idk how you use the 1850 beyond mowing, but the ss slope performance isn't in the same league as the 1850 from efficiency to safety. With the exceptions of lift capacity and pivot turn the skidsteer does not offer much in property management operations over the 1850.
The 1460 will not have the benefits of the 1850 surface area /wide stance on soft ground. Neither will the ss,w exceptions a few low ground pressure configurations .
/ Skid steer or 1460 #4
What kind of terrain are you planning on operating the skid steer on? I've seen many skid steers just tear the living %^&! out of the ground getting themselves unstuck. Tracked skid steer doesn't have those issues VS wheeled skid steer. If I was going to get into the the costs of a tracked skid steer, I'd be tempted to compare it to the costs of a compact telehandler or toolcat.
I'd think a 1460 would be a great machine for moving logs, loader work, brush clearing, forks, etc....
You've got some hard choices to weigh there, that's for sure. :)
/ Skid steer or 1460 #5
Do you work alone? With the skid steer, you can't get out of the cab with the arms raised. That is enough of an answer for me, that and the PT is easier to get in and out of. But if you get a brand name skid steer it will be better made and designed especially with high flow and all the different attachments that will get you. They lift higher, have more travel in the attachment tilt, have a universal quick attach with cheap more plentiful used implements. Skid steers will tear up your lawn, most will have a quieter engine. Unless you get an older one, they are much more advanced with many more control options, switches and safety features (that someday will need to be fixed). They probably have less or similar ground clearance, but when the going gets tough, all the wheels will drive. Tough choice.
/ Skid steer or 1460 #6
Or the JCB with the side boom that allow you to get out with the arm raised.
/ Skid steer or 1460 #7
Apples and oranges in my book.
What would you do with the 1460/skid steer?
All the best,
Peter
/ Skid steer or 1460 #8
I will stipulate that Power Tracs are cool, but they are not as robust as a skid steer. If Power Tracs were all that, there wouldn't be a skid steer market, and every contractor would own a Power Trac. If you like the articulating feature, buy this:
/ Skid steer or 1460 #9
Or This:
/ Skid steer or 1460 #10
Or This:
/ Skid steer or 1460 #11
Or This:
/ Skid steer or 1460 #12
Or This
/ Skid steer or 1460 #13
After using my PT1460 for a little while now, my impression is that it is a good loader-for the price.
After going through the fuel system, the Duetz starts the first turn every time and seems to be quite smooth for a deisel. I just moved 60 tons of stone for the driveway to the pond and the machine performed very well for that task. The rear tires spin somewhat when hitting the rock pile and this seems to limit the agressive digging action into the stone pile when compared to a skidsteer. The 4 in 1 bucket is good for moving stumps and driveway smoothing.
The front loader lift height seems to be lower and closer to the machine that the JD skid steer I am familiar with. If you want to load larger trucks with taller sides you will need something else. Dump trailers and trucks with lower sides no problem. The destruction to the ground surface with the articulated steering is way, way less than with a skid steer but the tight space mobility is limited compared to a skid steer. The machine is smoother and more comfortable to use due to the longer wheelbase. Skids beat the heck out of me and I do not enjoy operating them-although I have not used a tracked skid.
The attachment piece is a huge factor in my opinion. If your attachments will work with the 1460 attachment plate, that means you have quite a bit of functionality already. The PT1460 is not high flow. If you have any high flow attachments that you must have then that would be very important.
I have learned alot from your posts and you seem to do most of your maintenance and have made a bunch of custom attachments for yourself. That is so impressive. If you want to continue to do that then you will be ahead of the game since you already know so much. However, if you buy a skid steer, you will have a local service department and possibly warrenteed service so you can have someone else take care of any big issues that may come up.
If I had a larger budget for a machine, I would go for a newer style telehandler that is also capable of digging.
/ Skid steer or 1460 #14
If you watched the video, he explains how the Kubota loader does not have the hydraulic flow to run powered implements. It is just for grapples, 4 in 1 buckets etc. And yes skid steers are more robust.
/ Skid steer or 1460 #15
You left out GIant. I was comparing the Giant 1500 to the PT1445/1460. I was able to negotiate the price to only $4k more then a 1460, so it was worth looking it over. The giant is a much nicer machine with paint and fit and finish and even the engineering. The best feature was being able to lock all the wheels together (diff locks) even know it is hyd drive just like the PT. The 2 big issues with Giant and I would expect Mulitone and the others is not having the hydraulic oil cooling capacity to run a mulcher or brush hog/rotary cutter for any length of time. The other issue was side slope capabilities. The engineers at Giant told me it is good for a 4 precent side slope. What is the Power Trac, 30% without duals? (I don't know for sure on the PT, maybe someone can chime in).
/ Skid steer or 1460 #16
It depends on which model of PT you're looking at. Their slope mowers are good for 100% side slope. 100%. That's a 45 degree angle. You will never see any of those machines shown, or any skid steer, operating on anything anywhere near those slopes.
My little PT425, for example, is good for 25 degree angle, so that works out to something between 45-48% side slope, I believe.
I have no idea of what the other PT models are rated for.
/ Skid steer or 1460 #18
It has been well documented on TBN that Power Tracs are better than CUTs. No we know they are also better than skidsteers :p
/ Skid steer or 1460 #19
To each his own. My little PT425 won't do what a skid steer can do, and likewise, a skid steer would be useless on my property for my tasks. A CUT would be next to useless, so I guess that's a step up. :laughing:
/ Skid steer or 1460 #20
I like Power Tracs. I just haven't had a religious conversion yet :cloud9:
