European Tym T475
/ European Tym T475 #1
EuroYanmar
Gold Member
Somewhere
Tractormatic
Good morning,
Here is it :
Nowe TYM TYM T475 - 94 PLN, , 22 - otomoto.pl
Mainly the same as the North American T474.
Some differences :
- do you notice the quick attach hooks on the rear end (picture 11). And you know what ? they slide !
- the general circuit breaker on the picture 6 (red knob on the front of the frame
, now mandatory in Europe) (picture 6)
-The mud guards (pics 1,2,6,7)
-5 years guarantee ? (tag on the door)
-And last : the price tag 94000 PLN = 24962 $ + taxes (including the implements on the pics).
Phil
Info : on the picture 7 you will see on the back the green TYM K1-C just here for a presentation in an Ag show. Interesting thing. Maybe for rice farming....
/ European Tym T475
Looks like they have the Tier 4 DPF diesel emissions in Europe too?
We have it already for more than 50 HP tractors and will have it for smaller tractors at the beginning of year 2021.
That's why new models are coming now to comply with this regulation.
Here Tier 4 is called Stage V.
Phil
/ European Tym T475 #5
Wonder if they will bring the front 3 point hitch system over to the rest of the world?
Front 3 pt hitches don't usually come with the tractor in Europe. It's mostly a dealer installed option.
One of the most common manufacturers is Zuidberg but there are lot more available, although not all will offer PTO option as well.
Personally, I think front 3 pt hitches with PTO would do very well in the US to be used with snowblowers and push blades, along with a lot more attachments. Also would be a lot let expensive than the proprietary front attachments that Kubota and JD uses.
/ European Tym T475
TYM norsky,
Excluding the OEM loaders, most of time, in Europe implements are made by third party manufacturers.
Just as Woods for US market tractors.
For Kubota it's Kvnerland who build implements and in fact, it is a company owned by Kubota.
What you see on the picture is made by a polish company and is only tagged "TYM" with a sticker.
As PTSG wrote, front hitches and front PTO are very common here and made by Zuidberg (present too in US) or others like Folger ect...
Look now at those things :
Here you have a Folger front hitch plus front PTO on a Branson F47 (Branson 4815 in US)
Here a special rear hook system (the german are very found of this kind)
And here, have a look on this adjustable right link :
Phil
/ European Tym T475 #7
Not to derail the thread too much Phil, but since you've mention the F47. There might be a F50 in the works for the European market.
The F50 would be equivalent to the 4815 in the US, as in, using the same A2300 4 cylinder engine.
We had the F47, which used a turbocharged A1700 engine, squeezing about 5 hp more than the F42. The F42 is equivalent to the 4015 in the US. There was no direct equivalent in the US to the F47 though.
EDIT: The F50 is actually being sold already in ROPS and Cab configs: Branson F50R 48PS (NEU) Schalter | Sievershofer Traktoren
/ European Tym T475
Hi Pedro,
I surf pretty well but, for sure, you're a better surfer than me.
I am have been searching for a long time on the web for the new 2021 stage V Bransons .
But with no success and...you found them on the Branson.de Forum
Google Translate
This one must be a Stage V engine.
Yet, there is nothing new on the Branson germany website.
Thank you for this info.
I may be interested in buying a Branson F50 ROPS but I don't like the fact there is no foot guard above the HST pedals
This feature is very important for me as I have a lot of branches, vines and dust coming into my feet when bushhoging in May or June.
And I like too the factory mounted true third function on the TYM..
Are you happy with your F36 ?
I saw you on a youtube video bushhoging a difficult ground in Portugal.
Phil
/ European Tym T475 #9
Hello Phil,
Yes, I do post on the German Branson forum occasionally. That's indeed where I go that info from. A couple Branson dealers and mechanics also post there and share some tips and how Branson is doing, etc.
Branson sure could invest a little bit on advertising the new stuff and updating the websites, both Global and US websites. They lack a lot of info on that department.
These new 2021 tractors are compliant to the Stage V European emission requirements, which also makes it a step ahead for when the Stage V also applies in the US.
I actually saw a pair of those shields you're talking about for sale on OLX (our Craigslist). It came from a vineyard tractor, either Deutz or Same.
I'm very pleased with my F36Rn. It has done everything I asked for and more. It's a bit too big for the propriety around my house, where I have two orchards, but the tight turning radius makes it a breeze. On the other hand, for the remote propriety up North, it's just about the perfect size.
I haven't had any issues with it yet. It only needed a brake linkage adjustment when it was new. It made quite a bit of gear noise when it was new, but now it's much much better. Still does it a little bit on high gears and just under load when roading. Also all the gears just slide much nicely and smoothly now.
The seat is awesome. It's a very complete seat with lots of adjustments, making for a very comfortable ride.
Now, I've done a lot of mods to it, but I'll say right away, it's mostly personal preference and probably too much free time. It's not actually needed, but does makes for a nicer experience. I've done things like adding work lights (front and back), extending the 3 pt lever and adding a rear lever for ease of attaching implements (like some cab tractors use), took a 2" spacer that comes from factory to raise the seat (but I'm short) and I've mounted a fire extinguisher.
The video of me bushhoging with it, it's actually the first time I've used the tractor and mower, so I was going slow and easy. I really need to make a new video as I now know what the tractor can do.
/ European Tym T475
Hello Phil,
Hi Pedro,
I know of course olx.pt. I saw on olx.pt that in Portugal there are many dealers for grey market tractors.
At once I thought I may buy one of those but I think a tractor would be easier to maintain if it is from the regular market.
Looking to your videos I see your grounds really looks like mines . That's the reason why a Branson or a Tym might be OK for me.
Now I am waiting for the new models of tractors coming on January. There will be a lot because of the stage V regulation.
For example : Kubota L2352, L2402 and L2502 (something like this...) . I guess they will be clones of the US Grand L.
But with an increase of the prices of 11 % (because of stage 5 DPF, Covid and ...who knows ?). That's a lot ! Kubota is not for me, really too expensive..
Phil
/ European Tym T475 #11
Hey Phil,
Oh I'm sure they will find an excuse to increase the prices. They can come up with all kinds of non sense to justify a price increase. :laughing:
I agree. Kubota is just too much and hard to justify the extra cost.
I can give you a little bit of the my tractor buying story.
This happened in 2017 and I had a fully restored Kubota B7000 plus homemade loader and a fully restored 1962 Toselli crawler tractor with 26 HP. Both of these tractors I was going to trade in for an used and bigger one.
After checking dealers for Kubota, Iseki, Kioti, Antonio Carraro, Landini and New Holland, pretty much all of them come at me with an arrogant and rude speech and after showing some pictures of the tractors I was going to trade in, they didn't care at all. I'm still waiting for a call of three dealers that said they would check out my tractors. The Kubota and Landini dealers were the worst of them all. I guess that most of the big dealers don't care for the little guys...
I finally was going on the road and decided to stop by the Branson dealer, which is actually the closest to me. It is a smaller dealer, only the boss, the mechanic and the accountant. I was looking for an used tractor but he gave me such a good deal on the Branson that I just couldn't refuse, plus he valued my two trade in tractors for a lot more that I was expecting. The tractor is bit too big as I said in the previous post but I can still make it work just fine.
The Antonio Carraro also give me a good price on the 4400F but since it was the first one I checked out, I was still waiting to check out other options. The loader would be a slight issue but not the end of the world as I could build one for my backhoe or just build one for the 3pt of the AC tractor.
I ended up getting the Branson for a bit less than €14.000. The equivalent Kubota L2351 is no less than €18.000 and doesn't even come with most features that the Branson came, like quick attach hooks, a set of remotes, telescopic stabilizers and some more stuff I can't recall right now.
I didn't check any TYM dealers because I don't think I have a dealer nearby nor on the routes I usually have to drive through, so didn't even came to mind to search more about it. The LS dealer wasn't available at the time I was dealer and ended up not going that route either as the Branson came up right after.
Later on that year, I did check a TYM T353. I could see right away that wasn't built as heavily as the Branson but it was still heavier than the competition. The main think I liked was the fact that it did come standard with the joystick valve with fender mounted controls. That would saved me a bit of the hassle when I built the loader for the Branson.
In the future, we plan on growing olive trees on some ground that we inherited from the passing away of my grandmother earlier this year, so I'm expecting to use the tractor a lot more for those kind of jobs, like mowing, tilling, maybe get a cultivator in the future. We don't want that land to just grow up on brush and stuff.
/ European Tym T475 #12
Love the color but hate the wheels and tires.
/ European Tym T475
Hey Phil,
Hi Pedro,
Thank you for your tractor buying story.
You are 100 % right, big dealers of big brands don't really care of little guys.
If you buy a 100 HP brand new Kubota, for sure the dealer will considerate you...
Better to buy a Branson or a Tym from a local familial dealer than a New Holland from the main dealer in the country....
I have too olive trees (only for oil). They are 300 years old and so overgrown and high that I would need an hydraulic platform cherry picker to prune them (not sure it is the correct english word !!). As they are on steep slopes this cherry picker should be tracked !
Phil
