R4041H Replacement Battery
/ R4041H Replacement Battery #1
SpaceBuckaroo
Member
Keokuk, Iowa
LS
I'm trying to find a equivalent battery to replace my 8 year old battery in my R4041H.
The dimensions are approx. 10 5/8L x 6 1/2W x 7 1/2Tall.
12vdc, 80AH
Anyone else able to find a standard battery that will fit?
/ R4041H Replacement Battery #2
12vdc, 80AH
battery size chart in the link so that you can search by group size. i always look for the most powerful battery that will fit.
BCI Battery Group Size Chart
/ R4041H Replacement Battery #4
Recheck your measurements. I just measured the battery on my R3039H. It too measured 6.5" across the top. But, look below the top and I think you will find that at the seam between the top and the case is wider.
The measurements on my battery match a Group 24 battery.
Most any competent parts store will easily be able to match your battery I'm sure.
12vdc, 80AH
I'm going to have to pull the battery out and bring it to a local store.
/ R4041H Replacement Battery #6
Don't overthink it. It is a Group 24 battery.
Google isn't much use as group dimensions are "not greater than". Even the parts counter computers are not much help.
Arm yourself with a tape measure and go to a store with a good battery selection. Here is one from O'Reilly with the part number of 24PRM. The sad part is that is now a $180 battery with only a 2-year warranty
2011 BMW 5 Series 528i Sedan (A61574)
2011 BMW 5 Series...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59912)
2016 FREIGHTLINER...
2021 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
2017 Ford E-Series FedEx Delivery Truck, 5.4L V8, Step Van Conversion (A63689)
2017 Ford E-Series...
2012 KOMATSU PC360LC-10 EXCAVATOR (A64279)
2012 KOMATSU...
Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
Kivel 48in Forks...
