Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #5,831
I would cut the extra off. I just wouldn't throw it away. You could always add it back in if necessary with connector links.
   / Pictures of your snow weapons #5,832
Wire them up, have you priced repair links lately?
   / Pictures of your snow weapons #5,836
Well the F-350 just plowed our so called Nor’easter
No breakdowns! Even a bind squirrel finds a nut once in a while :applause::applause:
   / Pictures of your snow weapons #5,837
Grainger Supply has them reasonable enough I think. I myself would probably weld the cut link but not everybody has that option. I watch for stuff like that on sale and then I have it when I need it. To me that beats wiring it up every year. Like my time/aggravation is worth something too. Each to their own!
   / Pictures of your snow weapons #5,838
Cold shuts or lap links would run about $1 each.. I usually use the lap links.. easy to apply and stay shut. Even repair the tractor cross links with them.. they hold up quite well for wear.
But not a great expense.. and agree with pmsmechanic.. wiring up long loose ends is a pain. But removing at least one cross link on Mo's chains looks entirely possible for a decent fit. But if Mo likes the chains that way, I've no problem with it. Just thought others seeking a better fit might like to know.
Here are chains that fit.. no bungee's or springs needed.
   / Pictures of your snow weapons #5,839
I guess i dont understand the issue with wiring up extra links. I purchased my chains in 2011, i wired up extra links then. I leave them wired up and never unwired them until i needed an extra link for new tires. It was a 1 time thing.
   / Pictures of your snow weapons #5,840
The chains I shortened had about a 4-5 cross chain overlap. What I did was modify a set of free chains from a small tractor to fit on my John Deere 955 when I had it and I guess that's how I viewed the op's problem. Tying up a few links is not an issue I agree.
My first snow removal tractor was a John Deere 400 with a homemade blade. Chains and weights were a necessity. Next was a 955 with a 420 loader. I made up a set of chains but never used them. I gave them to the person who bought my tractor. My 4410 has been stuck a few times but never to the extent that I couldn't push myself out of the snow. I've mostly had more than enough traction for pushing snow without chains and weights.
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
2016 Chevrolet Tahoe SUV (A56859)
2016 Chevrolet...
JOHN DEERE 644K WHEEL LOADER (A58214)
JOHN DEERE 644K...
1998 Mazda B2500 (A57149)
1998 Mazda B2500...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
