Collant dripping off oil pan 2008 TC30
   / Collant dripping off oil pan 2008 TC30 #11
That major failure can also mean the loss of a good motor. Granted it can be extremely difficult to find leaks and you do need to be motivated to find the leak before you tear everything apart.
You can remove anything in your way as long as you dont remove any cooling system parts. Fans, alternator, shrouds etc may all be necessary.
You do need to keep the system pressurized until you locate the leak.
   / Collant dripping off oil pan 2008 TC30 #12
We use to use spray foot powder to find oil seepage when it was hard to see. That would not work in this case because you can't get the can in there. Maybe load up a bendable straw with flour, get it aimed right, and use a blow gun to blow it above your drips. Maybe then you can use a mirror to see the trail? :confused3:
   / Collant dripping off oil pan 2008 TC30 #13
A coolant o'flow tank should be nearly empty when cold and nearly full when hot.
If so there might not be a leak.
If topped up cold the tank will overflow when hot and can leave one wondering where the wet spot came from.
   / Collant dripping off oil pan 2008 TC30 #15
Im guessing a coolant overflow tank when too full will redirect the excess coolant down a hose to the ground. The OP has a coolant leak dripping from the engine's oil pan.
   / Collant dripping off oil pan 2008 TC30 #16
So... OP it's been 3 days. What have you found?
   / Collant dripping off oil pan 2008 TC30 #17
He ran off with Kando..........
   / Collant dripping off oil pan 2008 TC30 #18
So you've never seen where an overflow hose was missing on a machine that old? I didn't get as good a look at one in the the OP's pics as you must have.
Some people hate 'puke tanks' tanks and remove them. Didn't see that item in the pics either. It's a 2008 model, not 'just pulled the trigger' & shown to be all there with warranty.
Apologies for not knowing the next pow'r Ball winning #s either. :p
   / Collant dripping off oil pan 2008 TC30 #19
Sorry if I offended you. Just a old 30+ year retired master mechanic's point of view.
   / Collant dripping off oil pan 2008 TC30 #20
Not offended at all. We're both guessing at this point. :)
I worked in car factories for 30 yrs flipped cars, built street racers, and wrenched AMF-era H-D bikes.
I'm but a retired Toolmaker, which as related to cars & tractors only means I can measure well and make good parts. :laughing:
378812 (A51573)
378812 (A51573)
2003 Walk-Behind Automatic Seed Spreader (A54811)
2003 Walk-Behind...
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
