I bought a 6' box blade, Agri- something brand 15 years ago and have been using it to maintain the rocky mile long private road to my house ever since. About a year ago while using the blade as a dozer with the tractor in reverse, the brace from the top of the blade to the top of the center link popped a weld and the blade rotated itself 180 degrees and ended up under the tractor, bending the center and the lower lift arm pin mounts. I got it pulled somewhat back into position with an engine hoist, come-alongs, and a 20 ton porta-power and rewelded. Happened a second time and I again rewelded it but with a more robust weld. Two weeks ago one of the lift arm pin mounts that I had gotten mostly straightened broke somewhat catastrophically. Needed sledge hammers and prybars to get it off the tractor. Was thinking I would go buy a new one as the road needed a lot of work even though the cost for a King Kutter at Tractor Supply was $900. I did notice the King Kutter was not a 100% welded up implement - parts of the hitch were bolted, especially the ones I had bent/broken on mine.
I saw a post on another board that a company called Broken Tractor.com actually carried implement parts and found they actually had King Kutter box blade parts. So I ordered the bent up top link parts. They came two days ago. Prior to that I had cut the old hitch completely off including the lift arm pin mounts. The old mounts/braces were 3"x3"x1/4" angles that were welded to the actual blade and to the cross arms that held the rippers and to the front cross brace. I cut them off at the front cross brace. I then found some 3"x24"x1/2" in the shop. I will bolt them to the existing angle and extend them out 5" so I can connect the top link braces and install the lift pins. I am essentially duplicating the design of the King Kutter. I also replaced the welded brace that goes from the blade to the top link with 2 ea 2"x30"x3/8" 3-pt hitch braces that bolt to the top of the blade and top link.
Everything is clamped together now waiting new bolt holes and maybe a tough of welding to stiffen things. Should be able to finish today. Tried to post photos but doesn't seem to work for me.
