Got spacers in, can't break wheel bolts/nuts - what next?
   / Got spacers in, can't break wheel bolts/nuts - what next? #1
ctgoldwing
Central Connecticut
L3800HST
So my Bro-Tek spacers arrived and I just got a break from work to do the install. Didn't get very far :(
Tried to break the bolts/nuts free while it was on the ground with an impact wrench. Makes a lot of noise but no movement. The guy that tightened these must be the big brother of the oil filter tightener.
Any suggestions?
   / Got spacers in, can't break wheel bolts/nuts - what next? #2
Any suggestions?
Spray the nuts/bolts with a penetrating oil. Let them soak for a while before trying it again.
   / Got spacers in, can't break wheel bolts/nuts - what next? #3
Breaker bar with a pipe on it.
   / Got spacers in, can't break wheel bolts/nuts - what next? #4
Don't complain about having tight wheel bolts & nuts. Pray you get all that stuff just as tight this time around.
I should have mentioned I sprayed them with WD40 an hour before I started. Maybe need more time.
Tractorguy I should have mentioned that was method 1 (mostly). I have a 30" breaker bar but with just me and a 10" extension all I managed to do was slip off the nut. Made me stop right there. I'll rope my son into giving me a hand - less chance of totally rounding the heads.
Rick I don't know if it will be as tight. I do know it will be tightened to spec tho :)
   / Got spacers in, can't break wheel bolts/nuts - what next? #6
Six point sockets are nice, less likely to round off. Most impact sockets are six point. Probably the best thing I bought that I wanted for years was a 3/4 drive socket set.
   / Got spacers in, can't break wheel bolts/nuts - what next? #7
Rusted on or painted on? If rusted, there is a product out there that I got at the local NAPA store. Deep Creep - that stuff is amazing. WD40 did not free a nut I needed to turn out. Repeated spraying got me no where. Deep Creep goes on as a foam, interacts with the rust, and goes all the way through the nut. WD40 does not penetrate well, despite the claims otherwise.
Deep Creep | Premium Penetrating Oil & Lubricant for Shop & Household
   / Got spacers in, can't break wheel bolts/nuts - what next? #9
How about a star wrench with two cheaters. May need someone to hold the thing centered. Must have used red Locktite so may take heat to loosen.
   / Got spacers in, can't break wheel bolts/nuts - what next? #10
Only an idiot would put red loctite on wheel hardware. OP just needs a 6 point socket (preferably 3/4 drive) and some real leverage.
Kawasaki Mule 2500 (A57149)
Kawasaki Mule 2500...
2005 Volvo VNL Truck, VIN # 4V4N19TG25N374995 (A57453)
2005 Volvo VNL...
2025 Swict 78in Bucket Skid Steer Attachment (A56857)
2025 Swict 78in...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E83NKE63062, Super Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
UNUSED FUTURE SGB20 20" HYD STUMP GRAB BUCKET (A58376)
UNUSED FUTURE...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
