Add Wheel weights to JD 1025R
   / Add Wheel weights to JD 1025R
Found this thread when doing an image search: https://www.tractorbynet.com/forums/attachments/133283-installing-wheel-weights-conveniently.html
View attachment 679305 View attachment 679306
If you put down some plywood it would work on your raw land.
Not sure if I'm replying correctly - do I "reply with quote"?
Thank you for your suggestions. I do have a floor jack like the orange one pictured. I confirmed with the dealer. they want $472 just for the labor to install the weights! I had actually thought about using a "ramp" as a lift as well.
As for taking them on and off to fix tire flats, I was not aware of that - thank you for pointing that out.
   / Add Wheel weights to JD 1025R #12
Now to the 1025R:
Wheel weights are a 70 lb then two 50lb weights for each tire. On the outside you add the 70lb one first, attach a second 50 lb weight, then on the inner side attach the third weight of 50 lbs.
Thank you for your time!
Just something to consider:
Consider Blue Locktiting wheel nuts before torqueing them down. Once all the wheel weights are on, how would you otherwise recheck the lug-nuts for tightness.
Still trying to figure out the extra wheel weight on the inside.
   / Add Wheel weights to JD 1025R #13
I used carriage bolts originally, but popped the heads off a few of them.
Good to know that is a risk. Most carriage bolts ARE grade 2.
If you want to respond to a particular suggestion it ties the conversation together if you reply with a quote.
For most punctures on tires without ballast you should be able to plug them on the tractor.
2012 Infiniti G25 Sedan (A53424)
2012 Infiniti G25...
2013 Husqvarna LGT2654 54in Riding Mower (A55853)
2013 Husqvarna...
golf cart (A55787)
golf cart (A55787)
2022 CATERPILLAR 246D3 SKID STEER (A52707)
2022 CATERPILLAR...
2014 Cadillac ATS Sedan (A55853)
2014 Cadillac ATS...
