TC40D Dash Glow Plug Light
   / TC40D Dash Glow Plug Light #1
zing77
Martinsburg, WV
New Holland TC40D
I own a 2001 TC40D. Just had a new engine installed and lots of items worked on. The tractor sits outside and is kept covered with a tarp. The one issue that bugs me is that when I first turn on the ignition switch, the glow plug light does not come on. Once the engine is started after a lot of cranking and warmed up, I turn the engine off. When I go to re-start, then the glow plug light comes on. I'm baffled and would appreciate any insight.
   / TC40D Dash Glow Plug Light #2
Have you checked the glow plug timer and relay?
I have not. Is there a way to test them? Also, I am a fairly new tractor owner. Could you direct me to the location of these? Thanks!
   / TC40D Dash Glow Plug Light #4
Mine Is under the panels on the left side of the tractor . Here is the picture I used to work on mine . My timer was missing replaced it and bought a relay and just replaced them . Think between the two I spent about 30 bucks . The one outlines in red is the timer IMG_7596.JPG
First thing, where did you find this sketch? Second, since the timer isn't even called out on the sketch, how do you find a part number?
   / TC40D Dash Glow Plug Light #6
You should be able to go to Messicks and other NH parts websites and find what you're looking for. i could find it for you, but you wouldn't like my finders fee.
   / TC40D Dash Glow Plug Light #7
Another member posted it a few years ago . I saved it . I just went to my dealer and bought the part . I think it was less then 20 bucks .
   / TC40D Dash Glow Plug Light #8
I’m wrong I got my timer on eBay and the relay from the dealer . Timer was about 65 bucks . I just did quick eBay search and found this one .IMG_7878.PNG
   / TC40D Dash Glow Plug Light #9
I’m wrong I got my timer on eBay and the relay from the dealer . Timer was about 65 bucks . I just did quick eBay search and found this one .View attachment 679701
This same model number timer is currently available (4) on E-Bay for $19.99 plus $4.05 shipping.
E-Bay listing # 324342380849.
There were 5 listed, I just bought one.
   / TC40D Dash Glow Plug Light #10
Good deal .
   / TC40D Dash Glow Plug Light #11
Zing77 - How to test the timer is attached....
Thanks to all of you for your replies. They have been most helpful. I think I'm on the right track now.
   / TC40D Dash Glow Plug Light #13
I have the same issue, though intermittently, with our similar vintage TC21D. Though I know that fixing the core issue is the right thing to do, I have found the by leaving the tractor in gear (or range on hystat), and turning the key to the start position, the glow plugs will light. Do this for about 10 seconds (starter will not be running because of gear interlock). Then release starter, shift into neutral, and re-engage starter. Should start right up.
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
2013 KOMATSU HM400-3 OFF ROAD DUMP TRUCK (A60429)
2013 KOMATSU...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
2015 MACK GRANITE GU713 DUMP TRUCK (A59823)
2015 MACK GRANITE...
Mower King Brush Cutter (A53317)
Mower King Brush...
