On Kubota TLB like L45, L39, CAN YOU RUN A HYDRAULIC DRIVEN FRONT MOWER?
   / On Kubota TLB like L45, L39, CAN YOU RUN A HYDRAULIC DRIVEN FRONT MOWER? #1
m5040
CT
Kubota M6040 L2250, JohnDeere 310D, Ford 841 Elenco, Ford 961, Trapmaster, PT180 w/LM bucket and 45" brush cutter, PT1430 Deutz w/grapple bucket, Antonio Carraro Tigrecar 6500. John Deere 5300. Former owned Steiner 430 max, Goldoni REV Maxter 7
Does anyone know if you can run hydraulic driven implements (like skid steer brush hog rotary cutters) from the loader quick attach on the Kubota loader backhoes?
I am thinking that the factory plumbed hydraulics are just for lift cylinders and not motors and the machine probably does not have an adequate hyd oil cooler for a high horsepower attachment.
I am speaking of a matched psi/flow motor. I believe the hyd circuits are in the neighbor of 11 gpm. I am not speaking of a high flow 30 gpm installed with only 11 gpm.
   / On Kubota TLB like L45, L39, CAN YOU RUN A HYDRAULIC DRIVEN FRONT MOWER? #2
I am thinking that the factory plumbed hydraulics [11 gpm for backhoe operation] are just for lift cylinders and not motors and the machine probably does not have an adequate hyd oil cooler for a high horsepower attachment.
<snip>
I concur with your thoughts as do others. While investigating stump grinders the vertical-axis grinders from Fecon were attractive but required skid steer oil flows. An hydraulic power pack appropriate for my L45's 32 HP PTO would have added over $5K to the cost of the implement.
   / On Kubota TLB like L45, L39, CAN YOU RUN A HYDRAULIC DRIVEN FRONT MOWER? #3
I think the best we can hope for on our low flow systems is a properly rated auger / post hole digger
   / On Kubota TLB like L45, L39, CAN YOU RUN A HYDRAULIC DRIVEN FRONT MOWER? #4
Titan makes a pto hydraulic power pac for their FEL rotary cutter. Their motors use two lines. The problem is not only flow but case drain, and always open discharge back to tank on large hydraulic motors and implements with spinning loads that can’t stop fast.
Offset weight becomes a quick issue for boom mowers.
   / On Kubota TLB like L45, L39, CAN YOU RUN A HYDRAULIC DRIVEN FRONT MOWER? #5
I have a L39 and have a hydraulic snowblower for the front. It runs on the factory front aux taps. I changed the motor to a smaller cu inch so it would turn faster for my 11 ish gpm. Copied the manufacturer’s smaller model. I don’t have a large area to blow so any over heating of oil hasn’t been noticed. Two passes on a 300 ft drive. I sure the cold weather helps the issue. Love the fact that mount and dismount is less than 2 minutes ( if I can get the flat face couplers to close)
2021 Kubota SVL75-2 Track Loader (A55315)
2021 Kubota...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
UNUSED JCT 84" HYD DOZER BLADE (A57193)
UNUSED JCT 84" HYD...
TAG 23" EXCAVATOR BUCKET (A57192)
TAG 23" EXCAVATOR...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2002 Bobcat 763 Compact Skid Steer (A56435)
2002 Bobcat 763...
