5' rotary cutter blades
   / 5' rotary cutter blades #1
SCWOOD
Easley S.C.
Kubota BX1800 Kioti CK2510H
I have a 5' cutter ( International World Agritech Corp RC20 )I have found blades for (World Agritech Corp IM5. Rotary Cutter Blades for 5' Mower)on ebay World Agritech Corp IM5. Rotary Cutter Blades for 5' Mower | eBay I am not sure these will fit my cutter.I don't know what the IM5 code is.If someone knows about this cutter and if the blades will work.Thanks!
   / 5' rotary cutter blades #2
At the risk of questioning the obvious, why do you want to replace your blades?
   / 5' rotary cutter blades #3
I hate to state the obvious but take measurements of your blades and compare.
That's the definite way to make sure you're buying the correct blades.
because the end of the blades are worn to the point I don't get full width.
Did not want to flip over just to measure blade.( When I get to the blades I wanted to have the new ones on hand to put on)That would be best.
   / 5' rotary cutter blades #6
I don't know how your mower is built. My King Kutter has a hole in the deck to access the bolt on one side and you can easily access the nut from the bottom. It may be difficult to break the bolt loose but there is no need to flip my deck to remove blades. Take a close look at your setup. You could get lucky.
   / 5' rotary cutter blades #7
Before crawling under your deck to get the removed blades out, make sure nothing is living under the deck that may be unfriendly!
2008 IC Corporation PB105 School Bus (A55973)
2008 IC...
2014 International Maxxforce DT (A53317)
2014 International...
Geismar powered by Stihl (A56435)
Geismar powered by...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
2014 Gravely 60" Zero Turn mower (A55973)
2014 Gravely 60"...
2015 DRAGON 130 BBL VACUUM TRAILER (A58214)
2015 DRAGON 130...
