For those of you that practice open-burning of leaves/brush..
/ For those of you that practice open-burning of leaves/brush.. #1
JTMachineDesign
Joshua Tree, California
LS MT125 TLB
Forgive me if this isn't 100% LS Tractor related - but I see many posts where folks are using their tractors in concert with gathering and burning debris so...
I'm California born and raised (ya, I know, I don't like it either but..). Here in most of the state it's totally illegal to open burn anything larger than a joint. You can ask for a permit and they *might* grant you one IF you basically hire the fire department to circle the pile with hoses on the ready and post a bond to cover any unintentional outcomes. Chipping, mulching and composting are the game here.. even pretty much all landfills allow plant matter for free and they chip/compost. We've been able to make a very productive home garden using compost to improve the horrible high-desert sandy soil.. anything too big to chip gets cut and stacked for future fires - indoors in airtight catalytic-converted spark arrested certified wood-stoves - (Can you believe many counties now only allow video screens of fires instead of fireplaces in new home construction??)
anyway...
isnt that huge burning mess and resulting burned pile of ashes a pain to deal with? how do you deal with it, if at all?
/ For those of you that practice open-burning of leaves/brush.. #2
I live in Missouri. I burn 2x year all the yard waste stuff that happens on our 80 acres - dead trees, bushes, low branches, leaves gathered from the yard, trail areas cleared, etc. Pretty big piles.
The pile burns hard for about and hour then smolders for the rest of the day. At the end there is just a pile of ashes.
I never do anything with the ashes. They either blow away or decompose - I can’t really tell. I use the same place all the time for burning.
MoKelly
/ For those of you that practice open-burning of leaves/brush.. #3
Ive burned trees and brush for many years. Ashes are never an issue. That being said, due to the fact that i live in 20 acres of trees i was always scared of starting a fire. Years ago i purchased a pto chipper and that is what i use within the trees. Works fast and produces a nice base for my trails. I still burn in open areas, but not as often.
Its actually not too much slower chipping than burning. When you burn within a forested area you end up having to haul trees and branches out to burn area anyways. I bring the chipper to the trees.
/ For those of you that practice open-burning of leaves/brush.. #4
I use the ashes to fill holes left by rotted stump holes.
/ For those of you that practice open-burning of leaves/brush.. #5
There’s no fire danger here and I haul in loads like this and burn them all the time. Once the ashes get to big I’ll lose them on the truck and dump them in a low spot. IMG_8704.JPGIMG_8717.JPG
/ For those of you that practice open-burning of leaves/brush.. #6
Wisconsin is much different than California.
Around here getting a burning permit is fairly easy but they definitely control what you can legally burn. Someone told me that when the ground is covered with snow you don’t need a burning permit but I’ve never actually checked to find out if that’s actually true.
/ For those of you that practice open-burning of leaves/brush.. #7
here in north idaho the permit is free, and done online. only limited in dry, hot time of year.
/ For those of you that practice open-burning of leaves/brush.. #8
If it's been really dry, the county will issue a burn ban for brush; Otherwise, all they ask is you notify the County Fire & Rescue of your intent. That's to keep them from dispatching units if someone calls about it. Burning in a barrel is allowed all the time without notice or restriction. That's how most folks out here get rid of paper trash. For barrel ashes, I simply strap the barrel on a FEL and go dump it on cactus. :cool: Hasn't killed any of it yet.
/ For those of you that practice open-burning of leaves/brush.. #9
Here in Michigan, a burn permit is required but it's free. I usually burn once a year when I just get too big a pile of limbs etc. When I'm done, I level whats left with the loader and the weeds and grass grow right over it.
/ For those of you that practice open-burning of leaves/brush.. #10
Just one of the many multitudes of reasons I don't live in certain places. I can pretty much do whatever I want, whenever I want as long as it doesn't bother anyone else directly. I can burn twelve months a year without any prior notice to anyone. I have to use great caution though. No windy days, make sure it stays clear of loose debris and grassy or wooded areas. Ash gets spread around and works back into the soil over time. I've had burn areas completely regrown nice green grass over the summer.
I'm as concerned about scorching paint as anything else, but one things spooked me during the last burn. I got concerned about a hydraulic hose suddenly letting go and spewing hot oil all over the fire area. Didn't happen, but .....
/ For those of you that practice open-burning of leaves/brush.. #11
I like having to have a permit. Our permits are free with the requirement of a minimum of 6” of snow on the ground. Helps keep down the jerks from starting forest fires.
/ For those of you that practice open-burning of leaves/brush.. #12
In Georgia a permit is as simple as a phone call or online to the Forestry commission..
I regularly open burn piles of debris, have campfires around where I'm working outside, open burn about 5 acres of planted pines I own to control underbrush.
Help my friend burn 50 acres of planted pines for same reason.
Drip torch can be your best friend on acreage that big, we both have one and all have harrowed fire breaks.
For as potash (third factor in fertilizer) that's left from debris pile burns or wood heaters/fireplaces that's great to scoop up and add around any fruit trees, grapevines or broadcast over garden area..
Btw threads like these can be created in the 👇
https://www.tractorbynet.com/forums/rural-living/
Rural living forum.
/ For those of you that practice open-burning of leaves/brush.. #13
I can burn anytime that there is not a burn restriction. That is dry spell in the summer. We can get a permit over the phone at no cost. If you burn without a permit and it gets out, you may be in trouble. I only burn in the middle of a large open space. And then only large amounts of brush and tree tops. I have piles of stuff that may set for years. They make good homes for critters and will rot down in a few years to dirt.
/ For those of you that practice open-burning of leaves/brush.. #14
In SC we can call the forestry commission to get a fire danger notice and if it's too high we don't burn. If it's not we just let them know we'll be burning and go about it. We had about an acre of high density trees cleared and it save me a lot of money to burn it over having it hauled off. I'll clear more periodically and burn the piles. Quickest way to get rid of it. If i could afford a chipper i'd go that route though. I've read that the ashes can be good for gardens. In the past i've just used the tractor to flatten out the ashes and the grass grew over pretty quick. Can't see where any previous piles were burned. It's also something fun for me and the kids to do. Our landfill will take tree/yard debris and mix it with food waste they pick up from restaurants and make compost. It was $8/yard but they just raised it to $25.
/ For those of you that practice open-burning of leaves/brush.. #15
I don't burn acreage at all. I only do piles and generally no more than about 10' diameter.
/ For those of you that practice open-burning of leaves/brush.. #16
I generally have an extremely large recreational campfire(permit not required) unless it's too dry.
/ For those of you that practice open-burning of leaves/brush.. #17
no permit in Arkansas and they will burn off fields that have hundreds of acres in them even when there is a burn ban in effect.
/ For those of you that practice open-burning of leaves/brush.. #18
I burn quite a bit as there is always branches or dead trees laying about.
This was one of my larger fires... farm (250 acres) had been timbered and they had TWO of these slash piles pretty close.
You can see in the upper picture the backhoe way in background to get some scale of the pile (and there were TWO of them)
Waited until one day when it literally poured rain all day. Got home about 4-5:00 PM and started the fire then as the place was soaked.
Had fire permit, phone, backhoe with me. About 3:00 A.M. I saw a light bouncing through the woods.... it was a sheriff. I was sitting in a spot between the two fires to keep warm (was getting cold at night) He walked up to me and had the "good ole boy" attitude...
I said "HI"
"What'cha doing?" He asked me
Thinking that was a mighty stupid question in light that I had two massive fires going, I said I was burning some slash.
"We've had a couple reports from across the lake.... with the sky lit up, they think there's a forest fire going on"
"nope... just me"
"How are you going to put this out???"
"Hmmmm.... (thinking that was a really stupid question) Well.... I've got my fire permit, cell phone, backhoe.... " (suggesting to him that since I STARTED the darn fire, I had NO intent of putting it out)
"Well.... (he says with an attitude) You DO know that you are REQUIRED to monitor your fire through the night, don't you???" (if you said "BOY" at the end in a condensencing tone, you have the idea)
I looked at my watch and said out loud to him...."and WHAT time is it right now???" (seeing as it's the middle of the freaking night and I'm sitting right here why don't you go shut your mouth was my thought)
He simply turned and said have a good night.
About 30 minutes later, I went home & went to bed.
Fire lasted couple days and I kept trying to push it upon itself to make it smaller to help get rid of things.
Normally when I have a "large" fire (nothing like these) I can use the front or rear buckets to keep pulling/pushing the fire into itself and frankly, by the time I'm done...the next morning there is literally nothing left but a pile of ashes.
/ For those of you that practice open-burning of leaves/brush.. #19
In my area, you can burn with no permit unless there is a burn ban during really dry periods.
/ For those of you that practice open-burning of leaves/brush.. #20
I just burned a large slash pile from the logging we did two years ago. I've never had the best time to burn. The loggers made 4 large piles spread about my property. I burned one the first winter after logging, maybe 2 weeks later. It was the smallest. Set it on fire and walked away. Came back a few hours later and pushed the half burned sticks and logs to the center to keep going. The second one was this spring. A bit larger. The WA State Department of morons decided to impose a burn ban in APRIL because we had a dry spring. The Fire Department came out, but the pile went up so fast, it was a smoldering pile of ashes when they arrived. They didnt fine me as that was the first day of the ban. That fire continued to smolder for a few days.
Yesterday, I went out and lit the third pile. This pile is the next largest. Probably 10 feet high, 30ft by 100ft rectangle of logs up to 8" in diameter combined with sticks as small as pine needles, all jumbled up into this massive pile. We currently have temps around 19F and about 2" of snow. The pile, though in the 'forest' is in a open area with the closest douglas fir about 30ft away. It took me about 2 hours to get it lit using nothing but a propane torch. Even though the material was well seasoned, the snow and dampness, rot, and unevenness of the material made it extremely hard to lite. But once it started, about noon yesterday, it went. It wasnt as fast as I hoped, but it did burn the majority of the pile throughout the night. It did leave behind the larger logs (the logs couldnt be harvested because of how crooked they were. They were diseased) So, now I do have a mess to clean up.
Now, some of you might be getting a bit freaked out when I said "Set it on fire, and walked away" or "it did burn the majority of the pile throughout the night." Understandable, how can anyone living in the forest leave a bon fire raging over night?! Calm down. The piles are in open areas, surrounded by snow. Everything is wet. Besides, I can see every pile from my house windows, and I monitored them while they were burning, from the comfort of my living room (it was 19F yesterday. :) )
So what do I do with the ash pile? Well, typically, nothing. The forest reclaims that land rather quickly. In some areas, I run the rototiller over the ash pile to incorporate the ash into the soil. Wood ash is actually beneficial, maybe not in the concentration that I am making, but it is what it is. Now this pile, that didnt burn completely, I'm not sure yet. As of this morning, the ashes where still smoldering and there are several large burned logs to deal with. I got a feeling that I'll have to get out the saw and get a bit dirty. What makes me more nervous is the last pile.
The last pile which is probably twice as big as the one I burned yesterday, is full of the same 'stuff.' Only the pile is pushed up against some large doug firs and near the county road. It is the pile that the loggers used to load out the trucks with. I'm not worried about the trees so much as I am about the road and the huge logs left behind. If it burns slow, like this last pile, instead of like the first or second one (that was gone within a few hours in a massive flame), that would be best.
I have struggled with the idea of getting a wood chipper to chip the material. I can use the chips after all. However, I cannot afford a chipper that will be able to handle large logs. And deconstructing this pile... yikes. I'm not lazy, but that would be a massive job. Interlocking large brush pile with large material in it.
I still dont know what to do.
Here is a photo of the pile I started yesterday, just as I got it going.
You can see, its a jumbled mess.
2017 CATERPILLAR 120M2 MOTORGRADER (A52709)
2017 CATERPILLAR...
2020 Ford F-150 Pickup Truck, VIN # 1FTEX1C57LKD02991 (A61165)
2020 Ford F-150...
2021 CATERPILLAR 259D3 SKID STEER (A62129)
2021 CATERPILLAR...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
2019 Chevrolet Express 2500 Cargo Van (A61568)
2019 Chevrolet...
2018 Kenworth T880 Quad Dump (A62613)
2018 Kenworth T880...
