New House Build in WV
   / New House Build in WV
How do you like the Zetor? Some would say it's an odd choice, but I came close to buying a Zetor myself about 20 years ago.
Your house looks well planned out. Simple and strong with lots of room is a good way to design for the build-it-yourselfer. Chosing to build very traditionally with a concrete basement with framing and sheathing on top makes sense for a homebuilder too. We built ours that way about 15 years ago and like you we had the fun of designing our own house from sketches... and then building it ourselves with subcontractors hired as needed. Anyone can build a simple frame house, and end up with their very own custom home. And then sit our on the porch, grow older, and be able to say, "Yep, we built it ourselves....mostly in the evenings after work. It was actually a lot of fun."
The fun part comes with making the right initial decisions on design, and that involves some luck for us amateurs. But I think you did a lot of things right. You just cannot have too much insulation, drainage, sturdy fastenings, waterproofing, or venting. All of which seem done right on yours. Hydronics too.
At your stage in our construction - before the insulation and drywall go up - my wife walked around inside with a video camera and made a complete video record of each framed room and wall in the house. About a dozen videos in all and labeled room by room. That gave us a permanent record of where all the electrical and plumbing was located in the walls, which has been a real handy thing to have through the years.
Now when I go to hang a picture, or put up shelving, or cut into a wall for anything I can first open the computer and look at the video to see what's inside the wall. Nice.
I wish I had done the same thing for all the utilities outside under the lawn.....some I did, but some I didn't even photograph.
Another thing we did right was to leave a lot of exposed knotty pine and hardwood trim inside which we varnished instead of painting. The contrast between off-white eggshell drywall and varnished wood came out right for us... although not everyone's preference I'm sure.
But varnishing the wood is an example of a small thing but important and hard to foresee. Selecting a varnish itself turned out to be a pain. My wife and I knew wooden sailboats, so we knew what we wanted was a traditional varnish that would last a long time, wear well, stand up to the sun without cracking, and be able to be recoated without having to remove the old varnish. Those are normal qualities in traditional natural varnishes, but those natural varnishes are getting hard to find and when we did find a good one they tended to be expensive. Le Tonkinois is a good example of an excellent natural varnish. Top notch product...but expensive.
I think that part of the problem with the expense of old style natural varnish is that the modern pseudo-varnishes like varathanes and urathanes have taken over the market in spite of their downsides. These synthetic varnishes eventually crack, discolor, and can't be easily re-coated without removing the old varnish. Smell weird, too. And they are expensive as well - although since they are a petroleum product that is probably because of profit more than raw materials.
The best cost solution for us was to step back and figure out how to mix our own varnish using a traditional formula. It took some experimenting, but it worked OK from the first and now we can say it has stood up for 15 years now. In places like exterior doors where our homemade varnish has weathered on the exterior, recoating it has been easy - just wash it, lightly sand (or more likely not even bother), and apply the new coat. It sticks and builds a deep lusterous coat. Just like a varnish should.
There's a lot of hints and kinks to home owners building their own place that we could probably write a book on the subject. Maybe someone should.
Anyway, I'll let you get back to work, and with our "Thank You" for allowing us to follow along with your build.
And please tell us a bit about how it is to have not one, but two unusual & older tractors? Has their age been a problem? Or is it an advantage?
rScotty
The Zetor is probably the best purchase I’ve ever made. I’d have a hard time getting by without it. It’s a fairly simple design and is a heavy workhorse. It had 312 hours on it when I got it 10 years ago. It’s now got around 850, and has been very reliable. Only issues have been minor, and cheap/easy to fix, like brake cylinders. It does have a couple of items needing attention now though. Mainly, l’m getting fuel leak back when it sits over night and I have to use the hand pump to pressure the system the first start of the day. Runs perfect after that though. That started during the build, so I have not had a chance to investigate. Not even sure where to begin looking yet, but figure it could be an o-ring in a fitting somewhere that has gone out, or maybe it’s the little pump that has the hand pump on it. I’ll figure it out at some point.
We did design the house ourselves and had a draftsman fine tune it into blueprints. We did our best to keep the design simple, with as few corners as possible, and utilize as much interior space as possible. Foyer is a bit big and could be viewed as wasted space, but it just worked out that way and it will make for a nice entry. Not sure I’ve shared the floor plan, so I will now. We have made a few minor changes as we went but nothing drastic.
I would go stained wood on everything, but Wife wants white cabinets and trim. White it is.
   / New House Build in WV #202
Good news today, windows will be delivered tomorrow!
That's great news!!! Be sure to tape them up so zero air can get past them. Air getting around the sides the windows is one of the biggest energy issues in most houses. I use ZIP Tape, that stuff is great.
I plan to do exactly that. I will tape the opening, caulk the flange, install with screws, then tape the flange. I agree, zip tape is awesome, I’ve used it for all sorts of stuff, and will likely always keep a roll or two around from now on.
Electric service is all hooked up, rope in the underground conduit, and ready for inspection tomorrow evening. Conduit is about 170’ and I just could not get my fish tape through it. I ended up tying mason string to a light piece of plastic, putting it in one end, and using a shop vac on the other end to suck it’ll through. Then used the mason string to pull in my 1/4” rope.
Lots of back and forth through the mud, but I finally got it. Sealed everything up without taking any pictures, unfortunately.
Now I may go check my windows out and start prepping for installing them.
   / New House Build in WV #205
Thank you for allowing us to watch your build progress.
White trim here too. Happy wife, happy life. :)
Did get Cherry cabinets though so not a total loss. :)
She feels like the white will brighten up the house, and she is probably right about that. With covered porches all the way across the front and back, it may be needed. I just like wood, but I’m fine either way as long as she is happy with it.
Got 2 windows installed, here is the kitchen window. Still need to tape the outside.
Unfortunately, I found that one of the windows is missing the nail fin. That’s a bummer....
Electric service inspection passed without issue. Power company has been notified of the approval, so hopefully we will have power on in the next 2-3 weeks, depending on their back log.
Managed to install the 3 - 3’x6’ living room windows this evening after the inspection.
Meeting with a small local cabinet company tomorrow evening to discuss kitchen cabinets and get pricing. Then hope to install the 2 double windows on the front of the house.
   / New House Build in WV #208
I also had no problem with the electrical inspection - other than having to change the covers on the outside receptacles. The ones I used were outdated codewise.
Absolutely agree with getting a cabinet company to put do the kitchen cabinets. That's what I did, too. Reasonable price and no hassle. If you use standard size cabinet doors, it is easy to change the "look" of the kitchen if you ever want to do so.
There are a few things I'd do differently in the kitchen if doing it again. One would be to leave more space under the kitchen sink for accessories. At the time we built nobody used RO systems for drinking water but now that is common. I put a 3 filter RO system in our kitchen and really like the taste of what it does to our water. But it was a squeeze to fit it all under the sink with enough space to change the filters.
The next under-sink RO system I do will either be remotely on the walk-in utility room wall, or if under the sink it will have longer hoses and mount on a vertical board that slides out on rollers to make it easy to service.
The other thing that I didn't leave room for was the new generation of wider double-door refrigerators. The cabinet maker built the cabinets right up to the fridge instead of surrounding the fridge with something removeable like a few inches of removeable facia. So we are stuck with one size of fridge. It's still large enough to be OK, but now we are storing more food than we used to do and the refrigerator space is limited.
Neither has really been a problem, but as long as we were putting in custom cabinets it would have been easy to leave some room for an unknown future instead of using every inch. We just don't know what the future will bring.
rScotty
rScotty
Fortunately, we only have to have the service inspected, I haven’t even begun the interior wiring other than putting some outlet and switch boxes in place.
Agree and the refrigerator space, we have already purchased the largest non-commercial refrigerator we could find, 30 cu. ft., so that is taken in consideration in the measurements. We also do not plan to completely surround it, it’s on the end of our kitchen and will only have a cabinet above it.
We priced one cabinet company, price was good, but service was not. Also priced Lowe’s, which seemed pretty expensive. The one we are going to tomorrow has been recommended by several people, so I’m hoping we do well enough there.
   / New House Build in WV #210
Your windows look close to the floor, when I built my house in 2000 the windows had to be a certain distance above the floor or they had to be glazed with safety glass. I think it was around 20 inches. I would hate for you to find out after the siding is finished.
72" Skidloader Bucket (A50775)
72" Skidloader...
20'x12' Livestock Metal Shed (A53316)
20'x12' Livestock...
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
Hydro Thumb Clamp (A53316)
Hydro Thumb Clamp...
2025 JMR 40in Single Cylinder Grapple Skid Steer Attachment (A55787)
2025 JMR 40in...
2017 Ram 4500 Bucket Truck (A55302)
2017 Ram 4500...
