Winterizing cabin -- which antifreeze
   / Winterizing cabin -- which antifreeze #1
DrRod
Ellicott City, MD - Farm in Orbisonia PA (south ce
John Deere 4110
For years, we have used RV antifreeze to prevent freezing in drain traps and toilets. I know not to use radiator antifreeze as it will kill all the good bacteria in the septic system. But today I noticed there is a choice of RV antifreeze at Home Depot:
a]. Ethyl Alcohol [$2.98]
b]. PG Formula and Glycerin Free [$4.98]
Both are rated to -50 degrees.
Is there any problem in using Glycerin or is there some other reason to go with PG Formula?
   / Winterizing cabin -- which antifreeze #2
As I understand it, propylene glycol ppg that contains glycerine aka glycerol is a byproduct of the biodiesel refinement process. Supposedly it has a distinct odor. “Normal” ppg which uses propylene oxide as raw material is nearly odorless. For the purposes of drain/trap antifreeze, the claim of glycerin free is simply marketing to justify the increased cost ?
I’m pretty sure I paid about $3.50 for a gallon of ppg RV antifreeze to close up our place last month from Wallyworld.
   / Winterizing cabin -- which antifreeze #4
Traps freeze because not blown out before adding antifreeze.
Glycerin is an alcohol.
Neutralize come Spring and septic shock not happen. Feed septic yeast before winterising, it can die off over months of nonuse. Solids settle and no digestion happens.
   / Winterizing cabin -- which antifreeze #6
I shop vac out the toilet bowl and add RV antifreeze then. Does not slush up anymore.
   / Winterizing cabin -- which antifreeze #7
Plastic jug vodka?? No?:D
POWER BNG2800IE INVERTER GENERATOR (A50854)
POWER BNG2800IE...
2013 KOMATSU PC490LC-10 EXCAVATOR (A51242)
2013 KOMATSU...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2017 MACK CHU613 TANDEM AXLE SLEEPER (A51222)
2017 MACK CHU613...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
