Price Check Grand L6060HSTC 4x4 ordered two days ago - hope I made the right call!
   / Grand L6060HSTC 4x4 ordered two days ago - hope I made the right call!
Knowing me, I would tap that 4x4 post a little too hard and would be wearing a snare drum around my neck. :rolleyes:
Lol!
Finally got around to taking some pics of the disc harrow and the grader scraper...
   / Grand L6060HSTC 4x4 ordered two days ago - hope I made the right call! #112
What is the small middle buster in the center of the disk for, never saw that before?
Its called a, center sweep. Purpose is to knock down the windrow that is often left down the middle by the front gang.
   / Grand L6060HSTC 4x4 ordered two days ago - hope I made the right call! #114
Thanks.
Hi all - been a while since posting šŸ™. Recently ordered a BH92 for this unit and included the hydraulic thumb. I didn’t initially worry about getting the quick attach and buckets but have since changed my mind. I just happened across some post about the two (hydraulic thumb and quick attach) not being compatible. Is that true? My dealer hasn’t said anything about so I’m wondering if I read the post incorrectly…?
   / Grand L6060HSTC 4x4 ordered two days ago - hope I made the right call! #116
I don’t have an answer for you on that but you’re gonna like that BH. Check your subframe bolts after awhile of use, I had a few that needed to be torqued up. I have the QA bucket and have the 18ā€ toothed bucket and I ordered a 16ā€ and removed the teeth, for a flat face. The thumb tines still work fine with the 16ā€. Have fun!
Thanks Pokey, will be sure to do that. On your 16ā€ bucket, when you say you removed the teeth…I assume you ground the mounting stubs flush to get a flat bucket edge?
   / Grand L6060HSTC 4x4 ordered two days ago - hope I made the right call! #118
Home - Werk-Brau
Yes, my fab guy did it and said it was a little bit of a PITA. Werk Brau used to make buckets for Kubota (I heard) and they may have a flat face already. The 16ā€ tooth bucket from Kubota is around $1,100. I got it for $900 a couple years ago. Don’t go less than 16ā€ or you’ll have trouble getting the bucket to empty.
23013 (A55787)
23013 (A55787)
2020 DRAGON ESP...
Eagle Weathervane (A55853)
Eagle Weathervane...
30KW GENERATOR (A58214)
30KW GENERATOR...
LOT: (10) Fuel Cans (A59076)
LOT: (10) Fuel...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
