Tires 2720 R3 Radial tire size
   / 2720 R3 Radial tire size #1
jpb6
Upstate NY
JD 2720
Hi,
I have a 2010 2720 with bias-ply R3 turf tires (front 24x8.5-14, rear 36x14.00-15). I want to replace them with new R3 radials. Does anyone know if these are available for older tractors? If so, do they need a different rim? What are the radial tire sizes (front and back)? JD part numbers would be very much appreciated!
Thanks!
Jump on this link and it will take you to the 2720 parts..
https://partscatalog.deere.com/jdrc/navigation/equipment/67836
Thanks for the reply! That link is very helpful for a lot of things, but doesn't appear to answer this question. I have not been able to find a radial R3 tire that would fit on the R3 JD rims I currently have. As you probably know, R4 and R3 (bias) tires require different size rims and cannot be interchanged without ruining the front drive train. If anyone has a 2720 with R3 radial tires, could you report what size the tires are and what rims they are mounted on? I have heard that the radials come in metric size. According to Tire Size Converter, the same size R3 metric front is 216/59R14 and rear is 356/75R15. No one seems to make tires in these sizes. I am assuming that the radials are a slightly different size than the bias but net out the same rolling circumference.
   / 2720 R3 Radial tire size #4
Contact your tire dealer. They will find the right tire combination and the right rims.
UPDATE:
My local JD dealer and tractor tire guys were unable to come up with a radial R3 tire and rim combo that would work on a 2720 without risking messing up the drive train. I ended up buying replacement bias-ply turf tires and mounting them on my existing rims. If anyone finds a solution, please post details. Thanks for reading/replying to my post.
Kubota L4701 (A53317)
Electric Mobility Scooter (A51694)
Electric Mobility...
2011 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2011 Ford F-150...
2017 KUBOTA SVL75-2 SKID STEER (A52707)
2017 KUBOTA...
2016 Chevrolet Tahoe SUV (A55973)
2016 Chevrolet...
2007 Saturn Sky Convertible Coupe (A55853)
2007 Saturn Sky...
