Best place to get a 3 point hitch kit for Kubota L3901 ??
   / Best place to get a 3 point hitch kit for Kubota L3901 ?? #11
I wouldn't spend a dime on a 3pt hitch and not buy it with extendable arms.
They're life savers when it comes time to hook up to another implement.
   / Best place to get a 3 point hitch kit for Kubota L3901 ?? #12
Agreed, wish I had extendable arms when working on equipment. Lol
   / Best place to get a 3 point hitch kit for Kubota L3901 ?? #13
Since the L3901 uses the same BH-77 backhoe as the LX-2610, and the 3-point hardware has to be removed to use that, I'd say that the 3-point hardware should be available if the tractor can be ordered with the backhoe already mounted. If you have a decent dealer in your area, he'll be more than willing to help you find out how to get it. You might have to purchase it as a lot of individual parts, dunno.
   / Best place to get a 3 point hitch kit for Kubota L3901 ?? #14
BH77 hoes are dealer installed and the tractors they fit are shipped with 3 pt linkages as standard equipment.
   / Best place to get a 3 point hitch kit for Kubota L3901 ?? #15
The question - "Where are the OEM arms" - has not been answered. Mayhaps the OP contacts the previous owner and - WHALAA - the lost will be found.
   / Best place to get a 3 point hitch kit for Kubota L3901 ?? #16
You are entirely correct. I eagerly await delivery of a BH-77 subframe for my LX2601SU, but have already taken delivery on the tractor. The dealer told me that they normally pack up the lift hardware in a box and deliver it with the tractor, especially since it's a removable backhoe. Apparently it's about a 30 minute job to put the lift hardware back on after removing the backhoe, so not really as quick a job to go from backhoe to bushhog as Messick's videos suggest. There's one where they show removing and re-installing the backhoe in under 7 minutes, including driving nearly 50 yards away from it, parking, shutting down the tractor and getting off to get a lap-time for removing the hoe, then they drove back to it, installed the backhoe, and returned to the same parking spot again. Impressive, but the only reason I can see for installing or removing the backhoe is the need to do something different from what the tractor was last used for. That ain't happening in 7 minutes. There's nowhere to hang additional ballast on the back, so the FEL use would have to be capped as well to prevent stability problems. Even with wheel ballast, I'm not sure I'd want to be lifting a full bucket of dirt.
   / Best place to get a 3 point hitch kit for Kubota L3901 ?? #17
Removing or installing your 3pt linkage is a 5 minute job if you have normal dexterity. Maybe 10 minutes the first time.
The entire process of removing the backhoe and installing the 3pt (or the reverse operation) shouldn't take a half hour after you have done it a few times. Much of your commentary is completely speculative and obviously not based on your own experience.
If Messick's produced a video showing an experienced person removing and reattaching the backhoe in 7 minutes it most likely happened whether you believe it or not.
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A56435)
2019 BOBCAT T630...
2005 CATERPILLAR 262B SKID STEER (A52709)
2005 CATERPILLAR...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
Blue Diamond 103709 (A53317)
Blue Diamond...
PALLET TOTE OF MISC (A58374)
PALLET TOTE OF...
2020 Husqvarna YTH22V46 46in Riding Mower (A56859)
2020 Husqvarna...
