MT125 Parts and Service Manuals
   / MT125 Parts and Service Manuals #1
jdeilus
Prince George, VA
LS MT 125 (still waiting for delivery)
Has anyone had any luck locating parts and service manuals online for the MT125? I seem some old posts, but seem to get nowhere. I’m looking for components to the FEL Joystick valve.
   / MT125 Parts and Service Manuals #3
Has anyone had any luck locating parts and service manuals online for the MT125? I seem some old posts, but seem to get nowhere. I知 looking for components to the FEL Joystick valve.
I'm looking too.. I've found really nice manuals including part numbers for the 1100 loader at https://www.rcotractor.com/fckimages/PDFs/ls-tractor-manuals/LL%201100%20OP%20Manual.pdf
For the 1100 backhoe at: https://www.rcotractor.com/fckimages/PDFs/ls-tractor-manuals/LB%201100%20OP%20Manual.pdf
but so far, only an operator's manual for the MT125, although it too is really nice. https://www.rcotractor.com/fckimages/PDFs/ls-tractor-manuals/MT%20125%20OP%20Manual.pdf
I think detail info on the sub-assemblies for the tractor will require calls to a decent dealer...
The valve is only sold as a complete unit. However, there is a YouTube video in which somebody repaired their valve using parts from Ebay. LS MT125 FEL Joystick Problem - YouTube
I seen that video. I was going to see if LS actually sells those pieces. Either way the tractor is under warranty. I was just looking to see if it something simple.
   / MT125 Parts and Service Manuals #5
Seems like we just had this thread. Check with your dealers. Many of us got them free on a thumbdrive or other media.
Gotta say, they're OK, but not spectacular.
Then again, if you're still waiting for delivery, or just got it, what is going on that you needs parts already?
   / MT125 Parts and Service Manuals #6
This is about it. I see discussion of removing and reinstalling it, but no discussion or diagrams of disassembly or internal parts.
Thanks, I’ll ask my dealer Monday if he can provide me with the manual. It’s too bad that if the problem I think I have is true, then the whole valve assembly will have to be replaced instead of parts that could cost 10 to 15 dollars. It will be on LS‘s dime anyway. Could LS be getting a little sloppy on the assembly line trying to push them out to quick? I have only 30 hours and already have this problem along with a bad seat safety switch wire and loose bolts on the backhoe valve.
What problem is that?
Too bad I couldn’t load a video. The joystick has way too much free travel moving left to right. Forward and back is good. The stick is not loose. The nut is very tight. The hex head bolts are tight too. There is a you tube video on this thread of someone that had the same problem around the same hours (30).
   / MT125 Parts and Service Manuals #10
Doubt you will find a parts breakdown of the internals of the loader valve.
2020 EAST TEXAS TRAILER STEAMER TRAILER (A53843)
2020 EAST TEXAS...
2006 Ford Ranger Ext. Cab Pickup Truck (A55788)
2006 Ford Ranger...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A56138)
2015 FREIGHTLINER...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
CK Power Generator (A53316)
CK Power Generator...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A55853)
2014 Glasstream...
