Does gas really go bad?
   / Does gas really go bad? #81
I fueled all the cars with Ethyl when I worked at the Dealership... they had one pump of High Octane Union 76
   / Does gas really go bad? #82
Think it can because there are a lot more chemicals in it that can chemically react, given time. Stuff even tastes and smells way different from the old, fresh gas we used to have. Change came when they took the lead out and had to leave or add back some chemicals in there for octane improvement. That was a LOONG time ago, before many of you were born.
Ralph
it was 1975 when they mandated the use of unleaded gas in cars with catalytic converters. Lead wasn't banned in the U.S. as a fuel additive until 1996, just 24 years ago.
https://web.mit.edu/ckolstad/www/Newell.pdf
   / Does gas really go bad? #83
Yep and leaded fuel dispensed through a larger nozzle that would not fit into the smaller unleaded fuel filler.
Friend had a Honda CVCC Civic year 1978 that was in very high demand because of 42 mpg, no CAT needed to meet smog and the 5spd was fun to drive.... I think this is what made Honda here...
It was nothing like the 2 cylinder 600 model from not that long ago.
   / Does gas really go bad? #84
Just counting off the top of my head, we have in order of use most to least:
4 running vehicles
the PT425
the push mower
weed eater/pole saw
2 chainsaws
pressure washer
log splitter
generator
And that's it. Just 12 gas engines. All use 87 octane E10. None go longer than about 11 months without use.
How many vehicles do you have in storage now? And what do you do to them to keep the fuel issues at bay?
I have, in order of use;
(2) on road pickups
chainsaw
snowsled
wood splitter
ATV
off road pickup
Troybilt tiller
semi trash water pump
walk behind string trimmer
Dirt shredder/hammermill
spare chainsaw
welder/generator
outboard motor
string trimmer/cultivator (used to see more use but I forgot to drain the fuel last year.)
ice auger
generator
THe only things which run E-10 are my pickups, and snowsled for most of the winter. For the last few tanks I burn non-ethanol, then run them dry in spring.
I also have an antique snowsled, 1953 Ferguson TO35, and Ariens snowblower, all of which I need to get running because they were stored with fuel in them.
The best way that I've found to clean old tarnished fuel tanks is with paint stripper, followed by a pressure washer.
   / Does gas really go bad? #85
A friend of mine had a 80's CRX economy model that averaged 55mpg. It was a D-O-G dog, but man, it sipped the fuel. I was driving a 3/4 ton GMC with a 454 that got about 8mpg. :laughing:
   / Does gas really go bad? #86
Sometimes I think we live parallel lives in alternate universes!
My go to neighbors growing up both came from Kokomo Indiana... I was always invited to make a trip back with them but like so many other things that get put off and then too late.
Oh, they met in CA as singles but she was always the girl from home... back then it seemed like almost everyone was from somewhere else... especially the Bay Area with military and defense.
All this talk about gas going bad is giving me nightmares.... The I/O SeaRay was garaged with 40 gallons 8 years ago...
   / Does gas really go bad? #87
Been to Kokomo many times. Probably well over 100. I have family in Indy and Cinci, so we traveled through it since I was born. Always stopped there to stretch the legs, have a bite to eat. Mom used to like the mall there. I was just through it twice last week on the way to Oklahoma and back.
When I was a kid I remember you could see it miles off in the distance because they had a 40 story natural gas tower there, just like the one we had in South Bend. It looked like a green silo with a red and white checkerboard top. They imploded it in 2003.
They had quite the automotive industry there. Still do, but just not as many people employed as when I was a kid.
Chrysler and Delphi(formerly Delco) are still there.
   / Does gas really go bad? #88
He was quite a mechanic and superintendent manufacturing industrial gases... there was not anything he couldn't fix and in later years became good friends with Chuck Yeager who also came from Indiana?
Still remember the terrible smell from an old jeep he had picked up. The fuel tank had to be boiled out clean...
   / Does gas really go bad? #89
When's the last time you had a fuel line freeze using E10 gasoline?
THe last time that I had any fuel line freeze was in or around 2000, when my snowsled tank somehow got water in it. (See my comment above about putting the stale gas in the snowblower.)
I believe that sled had the filler tank in front, and I sometimes plow through a lot of snow.
   / Does gas really go bad? #90
I used to drive through Kokomo until they built the second bypass. Now I generally drive around it.
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2010 MACK MRU613 GARBAGE TRUCK (A51243)
2010 MACK MRU613...
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A52128)
2004 Capacity Yard...
UNUSED CFG Industrial QK18R Mini Excavator (A47384)
UNUSED CFG...
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
