JD 4300 stops moving in forward and reverse after a few minutes - engine still runs
   / JD 4300 stops moving in forward and reverse after a few minutes - engine still runs #51
Is it fixed? For the steering valve to be causing the problem, it would have to be forcing all the flow over the relief. Running without a suction screen, probably got crud in it. I bet it just needs disassembled and crud cleaned out. Most dealers just put new parts in because it's easier and less liability. Screenshot_20201113-213217.jpg
Thanks for the update. Something else to consider. I assume this is the hydraulic 'valve' under the dash. Sounds like the failed component caused low precharge pressure.
yes, it was the unit under the control panel.
It does seem to be fixed. I've only put a few hours on the tractor this morning but so far so good. The steering control unit is not all that serviceable. The dealer closest to me actually has a decent service department that tried to clean it out but it does not come fully apart and they could not restore it.
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
2024 New Holland Skid Steer (A52377)
2024 New Holland...
2020 Freightliner M2 106 Elgin Whirlwind Series MV Street Sweeper Truck (A55852)
2020 Freightliner...
2018 John Deere 2025R Tractor - 647 Hours (A57024)
2018 John Deere...
John Deere 1025R (A53317)
John Deere 1025R...
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
