You already have "lifting" blades.
To be sure we are on the same page,the blades in post #16 are what's found on most cutters and have years of life left and you would only be wearing them out by sharpening. Are the blades in post #1 and post #16 one and the same (they look like totaly different type blades)? I totally agree that the rocks you describe shouldn't do much if any damage. At any rate,sharpening blades in post #1 only reduce's blade life without improving preformance "IF" they continue being used in same field. I wouldn't worry about LIFT or no LIFT,that's only relivent with lawn mowers. Claims of lift for pasture cutters is sales pitch hype. For the record,the ability to cut trees and brush increase's with mower quility and price. Bush Hog and Service mowers will cut anything the tractor can bend over and do as well in weeds and grass as anything you can buy at tractor supply or elsewhere. Yes,Bush Hog is a brand name so stop calling all cutters Bush Hogs.
I think it's universally agreed the blades will not benifit from sharping but you say they don't do as well as they did earlier. May I suggest checking deck height to see if that might be some of the problem? Adjust deck so that blades are closer to ground when at front of deck. When blades are level or higher in front,weeds are clipped a secound time as they pass rear of deck. That secound clip leave's a ragged top on stem ,slow's blade and sap's horsepower. It's the same as cutting weeds with a machete. If you swing and cut weed mid-way between top and ground then swing a secound time attempting to cut stem 4" lower,the cut isn't as clean (if it cut's at all).
I think we all do the same. Just like we use "Kleenex" to describe a facial tissue even though it may not be a Kleenex. The companies certainly don't mind as long as it's not used for advertising. They get their name mentioned more frequently. Isn't that the reason for a brand name? :confused3:Re: Bush Hog, I will sometimes use the term "brush hog" because that is what it is sometimes called around here, but yes, I realize it's not Bush Hog.
View attachment 676283View attachment 676284View attachment 676285
After 6 years of cutting brush, rocks, bricks, stumps, and what ever else was on the ground, this is/was my 48” rotary cutter blade.
Luckily it didn’t travel too far.
