Driveway trailer ruts
/ Driveway trailer ruts #1
kj3
Member
Tennessee
Satoh Bull (Mitsubishi)
We have a trailer that weighs in around 2 tons and used Monday through Friday, at the end of the day about 50 gallons of water is drained out. Between that daily dose of water plus any rain it doesn't help our situation. Over the years I've tried different solutions and using a hose from the trailer so it drains out 10 feet away and down the slope. But the ruts still come back pretty soon. My last effort was using 4" thick 16" wide blocks to part the trailer on but you can see they ended up sinking in on one site or the other. You can see how that looked after a season.
The driveway is a couple hundred feet long and gravel, fairly level and been in place for a couple of decades. Ideally the best solution won't involve a drastic change in appearance or create a big lip changing from one material to another. I'm open to any good ideas, nothing is out of question except but I hope something less costly than just pouring a 14x20' concrete pad. Even with concrete there would still be some concern about drainage and the slope just beyond the parking area, having it crack off.
Do we need to add more gravel, big gravel then a layer of smaller? How thick. What about geogrid? Anyone who's fixed a parking area in front of their barn or whatever I'd love to hear what worked or even did not work so I can avoid mistakes. Thanks in advance!
/ Driveway trailer ruts #2
dig it out, install base 3x4 rock geoteck fabric gravel. small French design would help.
what do you mean by 50 gallons water drain out?
/ Driveway trailer ruts #3
There's nothing unusual about weight sinking if sitting in a mudhole. Look at those craters where wheels set. Raise the parking spot above grade,cap it with asphalt (new or recycled) or concrete so that water is shed when it rains and drain daily 50 gallons elsewhere before parking.
/ Driveway trailer ruts #4
why does the trailer get 50 gallons (a day) in it in the first place?
looks like your road has no base to it.
/ Driveway trailer ruts #5
Wrong gravel, IMO. You need something that locks together to shed water away. Crusher Run / Crush and run - you have so much air space between the rocks I would consider a dirt layer on top of what you have, compact it, then add 4" of Crusher Run on top of that. Right now you have a muddy pond under your gravel and it will continue to sink when it's wet.
Well its used for work and at the end of the day fresh water is filled and the dirty water is drained. Thanks.
What is 3x4 rock, google has let me down on this one? Did you mean 3/4"? Definitely thinking some deeper channel of gravel at the edge might help with drainage. Thanks again.
/ Driveway trailer ruts #7
I would scrape off the small gravel dig down and put in 8+" of 3-4" rock. Put the small gravel back on and top it off with clean gravel.
/ Driveway trailer ruts #8
I second this suggestion. I had a school bus coming into my yard and turning around twice a day - it created a real mess. All the levelling and road crush made no difference.
Scraping off the top and putting in a layer of 3-4” rock and then road crush / small gravel fixed it. Never had another problem.
/ Driveway trailer ruts #9
Haven't y'all ever heard advice that say's "when you find yourself in a hole,stop digging"? I believe that applies here. It is universally agreed that present rock is too large and need's airspace filled with smaller material. Digging out present rock just stir's up loose soil and mixes dirt with existing rock. Next time it rains, all that dirt turn's to mud and sinks. No need to spend time digging,put a layer of pea gravel on top of what's there to fill gaps,put a layer of fines over that to fill gaps in pea gravel and finish off with material that set's up to shed water. Collectivly,those layers will raise pad above grade.
/ Driveway trailer ruts #10
When I want to build a good road I put down a base of 1-3” rock and top with crusher run. If the ground is already pretty solid I just dump crusher run or clean 1” down.
When I want to build a good road I put down a base of 1-3 rock and top with crusher run. If the ground is already pretty solid I just dump crusher run or clean 1 down.
Alright, the consensus so far seems to be a load of large gravel, the existing couple of inches was probably 3/4 - 1" range with a bit more we added on top some years ago. You can't tell because so much just mashed in.. Under that the soil is mostly clay, for whatever that is worth. I'm going to look at leveling the area by filing in the ruts then dropping some 3" gravel on top. Add a layer of finer gravel on top of that. I have seen some ads for road millings and I've been impressed where the road crew used that for the new culvert installed a couple of years ago. That stuff packed in great.
I'm hoping about 4" total will do it, not opposed to spending a bit more but I'm guessing this 20x20' area can all be done for $400-600 total. Still wondering if a fabric would be good to lay down before the load of big gravel.
Thanks guys. Still interested if someone else pipes up with experience but I think PandD spoke with a perfect example, hard to beat a school bus for comparison. How thick did you pour on the 3" gravel?
/ Driveway trailer ruts #12
No, No, No. Don't use pea gravel or any kind of rounded rock for a driving surface. It's like driving on marbles. I put down 4" of river gravel for a parking pad one time because that was all i could get. I got my car on it, but it wasn't coming off. I could either call a tow truck or start shoveling. Only use crushed stone or crushed concrete that will lock together.
/ Driveway trailer ruts #13
The idea is to have pea gravel work it's way down through the large stuff to fill gaps. You omitted those two words when you highlighted what I said.
/ Driveway trailer ruts #14
Level off what you got there. It doesn’t have any fines so it will not pack. Properly. Then add three quarters or half inch crushed gravel that is well graded and compact. Add till you get the firmness you desire. Then you can add the concrete tire pads.
/ Driveway trailer ruts #15
I will never again put down large crushed rock on a driveway that will be used for cars. I fought those big spikes coming up through the small stuff for a number of years and cost me a lot of tires. If it is really muddy use road fabric under 1 1/4 minus and then 5/8 minus over that.
A crown and drainage is the key to a successful road maintenance program. If you are building it through a swamp then there is no rock that will likely save you. Water is the enemy of roads.
/ Driveway trailer ruts #16
If you want to fix the problem fabric is the way to go. Otherwise you will be dealing with this again in a few years. I've learned it the hard way. Not sure if you get frost down there but the ground freezing will compound the problem.
Yes, we get freezing around here. So a couple of people have recommended some road fabric. I should ask what type you have used? This is a new direction.
/ Driveway trailer ruts #18
Yeah...road fabric...I researched this previously when folks suggested using it. Although could not determine what they were specifically recommending or where they sourced it from.
There is fabric listed on Amazon, but what I saw didn't seem reasonably heavy for driveway use...and the other extreme was commercial "big rolls $$$" with a few hundred just for delivery costs.
Always wondered what people on TBN have purchased and used successfully...
/ Driveway trailer ruts #19
Just fill it in with the 3" as well. isnt the point to add something in the ruts to support the weight?
After its leveled out the way you want..... order some 1 1/4 crush to top it with. when the truck arrives have the driver run back and forth over the 3" a few times to pound it down then add the 1 1/4" over the top.
For me.... I would finish it off with a layer of dirt or organic fines to mash in between the 1 1/4" crush. makes a nice surface and aids in water runoff. and yes no matter what you do you need to maintain it.
/ Driveway trailer ruts #20
I would use the fabric, we can buy it at our local farm supply, I think the last I bought was around $2/ft for 15' wide. Remove the gravel you have, put down the cloth, cover with 6-8" of packable gravel. Farms will often use this in high livestock traffic areas on steep slopes, I just put in about 360' through a wet/slick area and up a slope for a farm road. Seems to be holding up well.
The cloth keeps the gravel from disappearing in the mud/clay.
MIRRORS, MARKER LIGHTS, SWITCHES (A64276)
MIRRORS, MARKER...
GRACO KING XL45 PROTECTIVE COATING SPRAYER (A67714)
GRACO KING XL45...
PORTA POTTY (A67714)
2022 INTERNATIONAL MV607 S/A 26FT NON CDL BOX TRUCK (A69167)
2022 INTERNATIONAL...
2017 Ford F-250 Ext. Cab Service Truck (A66736)
2017 Ford F-250...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A66734)
2025 BrushFox...
