Euro/global/quickie tool carrier for loader
   / Euro/global/quickie tool carrier for loader #1
thoner7
to-20 Ferguson and Kubota m5400 with Quickie loader
I have a quickie brand 710 loader. It's on a 55 hp Kubota.
From my understanding, there's a few different sizes of the euro global attachment system; my manuel shows a few different mounting styles. The tool carrier for the bucket I have is very clearly what the manual calls "Euro (8)" . I cannot find much about the "Euro (8)" online
I'm wanting to a blank plate sytem like one of the ones in the links below. These look to be right, with the offset upper and lower attacent points, and the measurements seem correct, but I don't want to order something that won't fit.
Anyone have more experiences with these? Will one of these for my Euro 8 carrier?
846 Global 1/4" Thick Mount Plate Fits John Deere
Global Quicke Euro Tractor Loader Blank Mount Plate – Free Ship – Skid Steer Attachment Depot
   / Euro/global/quickie tool carrier for loader #2
Here is some info I have from when I build my loader. I used the Euro style coupler, although, I had to change some dimensions to fit my needs.
   / Euro/global/quickie tool carrier for loader #3
The bottom one in the picture that ptsg posted is what I have always seen called a Euro mount.
The first one you have linked to that is called a Global for a deere looks almost right,
except for the diameter of the lower hole they look small, it may be an optical illusion.
The link to the second one looks correct to me, that is what would fit are tractors with the Global hitch.
From the reading I've done, I thought the global and euro design was the same thing/interchangable .
Maybe I should call a Jd dealer? They should know of a euro 8 style bucket would fit one of their global loaders right?
So looking at those lower holes, my pins are probably only 5/8" and looks like the first one from titan would be a more snug/ proper fit
   / Euro/global/quickie tool carrier for loader #6
From what I've heard and read that would be correct, but I have heard that Deere has one they call Global which doesn't fit.
It could very well be correct I will have to try and remember the next time I get over to the farm to look at the lower pin size.
I went and tried to find out the proper diameter,
it seems to be 23 or 25 mm ,
23 mm = 0.9055 inch
25 mm = 0.9843 inch
good luck
   / Euro/global/quickie tool carrier for loader #7
I also have a Quicke brand loader (x2) on my m7060. I was lead to believe the attachment was called a Euro/global or ALO style. Mine resembles the bottom pic as shown above. The holes in the lower mount on mine are about 1” holes, and the pins on the tool carrier are something near 3/4. There is a bit of slop. This was the bucket that came with it new. The forks I have are the same way.
The bottom mounting hole brackets are 31” outside to outside, the top hooks are 42 1/2” outside to outside
Mine looks just like that too. Measurements sound right. But I'm still not positive those ones in my link are that size.
2015 Audi A4 Sedan (A56859)
2015 Audi A4 Sedan...
2015 Freightliner Derrick Digger Truck (A55973)
2015 Freightliner...
2018 RoGator 1100C (A56436)
2018 RoGator 1100C...
2013 Ford E-250 Cargo Van (A56858)
2013 Ford E-250...
43055 (A55851)
43055 (A55851)
Hr:2185.1 jihn Deere (A56857)
Hr:2185.1 jihn...
