Would you buy your Kioti (or another) again?
   / Would you buy your Kioti (or another) again? #101
I have occasional float issue also...pops out. It is a simple fix, i even have the part....in a box on the shelf. But i never get around to fixing it. Actually it isnt much of an issue.
   / Would you buy your Kioti (or another) again? #102
Curiously, what fails in it and how easy is it to repair?
   / Would you buy your Kioti (or another) again? #103
My float isn't working since I broke my joystick. I repaired it but 'float ' still isn't working. Haven't looked at why yet.
   / Would you buy your Kioti (or another) again? #104
its called a positioner. its easy to replace, you just need to not be as lazy as i am. i actually got the part while tractor was under warranty about 6 years ago. still sitting on shelf. i hear that the part is not cheap though. with mine, the problem is it keep starting to work again. it did after i got the part. then failed during the winter. the next spring it was working again. its now working again. go figure. heres a few pics of it/ 20201102_144926.jpg 20201102_144940.jpg 20201102_144950.jpg 20201102_145030.jpg
   / Would you buy your Kioti (or another) again? #105
I have the same year & model with a bit over 1000 hr, and I agree it's a solid tractor. Feels a lot more stable on uneven terrain than the JD750 I had before.
FEL joystick acts kind of funky in float position (jumps out a lot, sometimes doesn't go into float mode). Probably a simple fix, but not sure how those things work.
Really, my only gripes are that the operating position could be a little better laid out...easy to bump the key with your knee, hook pants cuff on the PTO lever, etc. but all in all I'm happy with it.
Agreed I’m short 5’5”-1/4” LOL
And I’m constantly hitting key with knee and turning on the aux lights with other knee.
   / Would you buy your Kioti (or another) again? #106
I am always bumping my key and accidentally switching it off. I looked at moving it but it was a lot of work.
   / Would you buy your Kioti (or another) again? #107
Many floats on different makes ofl machines tend to wear out quite quickly. A few spring loaded balls at the end of the spool. Often a kit is available. I think the tolerences are just extremely tight because to look at a used non-functioning one, you couldn't tell that anything was worn out.
TIP: Grease up the balls before you try and put the new one together.
   / Would you buy your Kioti (or another) again? #108
In my case I had leaky o- ring and the oil caused the float balls to be slippery and not hold. Oh and I just replaced another leaking o-ring in backhoe valve body. Will no longer use factory o-rings, they turn to jelly. I’ve replaced them all.
   / Would you buy your Kioti (or another) again? #109
Interesting, did you replace the O-rings between all the valves in the stack? I need to do that for my hoe valve.
Just did the 400-hr service on my 2005 CK30, now at 853h and no serious problems.
   / Would you buy your Kioti (or another) again? #110
Sorry I did not, I replaced all the spool valve o-rings
Giyi Pallet Forks (A53314)
Giyi Pallet Forks...
John Deere Quick Attach Forks (A56469)
John Deere Quick...
UNUSED FUTURE EQUIPMENT SEAT (A57193)
UNUSED FUTURE...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A55315)
2023 New Holland...
Ford 4630 (A53317)
Ford 4630 (A53317)
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
