How does an HST compare in pulling power with the same tractor and a gear trans?
/ How does an HST compare in pulling power with the same tractor and a gear trans? #81
How does a HST compare in pulling FORCE with the same tractor and a geared trans?
I think a lot of the answers here are for that question.
The HST might deliver more force than the 1st gear of a manual transmission. Plus it can probably be more smoothly applied than a clutch transmission.
/ How does an HST compare in pulling power with the same tractor and a gear trans? #82
Back in the day, I was looking to buy a NEW dozer... I already had a hystat dozer and just wanted something a bit bigger/newer.
My trip to the deere dealer, I learned that hystat dozers were pretty much junk! He explained to me how in many ways the power shift dozer was MUCH better and more efficient, he talked Case dozers down because they had hystats!!
Funny thing is, a couple years later pretty much all the deere dozers had hystats!!
SR
I see that Cat is still using Power Shift transmissions once you get out of what they call small,
I believe that D6 and up are all power shift, hydrostatic in the smaller ones.
/ How does an HST compare in pulling power with the same tractor and a gear trans? #83
Mat4644;5851736[B said:
]No need for pulling duels. [/B]Both have been dyno tested and gear is approximately 10% more efficient and more HP delivered. Reliability testing shows HST wears faster. Repair data also shows less repairs even on glide shift gear transmissions. You also take a significant PTO HP hit.
Even with obvious gear transmission advantages my personal preference are HST drive for convenience. Even though if doing loader and material transport work one still does a fair amount of shifting with the gear ranges.
Ah, but it's more fun that way!!! ;)
/ How does an HST compare in pulling power with the same tractor and a gear trans? #84
Many years ago, the fuel economy push in cars lead to the development of the "Lockup Converter". This magnetically connected the motor to the transmission and bypassed the torque converter (pump). Seems like that would work just fine for smooth transitions from stopped or upshifting, plus the savings in fuel from torque converter slip and the avoidance of excess heat generation. Two equivalent machines with direct drive ought to then be the same dyno power.
/ How does an HST compare in pulling power with the same tractor and a gear trans? #85
One thing no one has mentioned that I myself forget at times is that pushing your foot down on the pedal of the HST is not the same as the gear. On the HST you are in essence changing the gear ratio. You are pushing fluid faster. With the gear you are creating more HP through the increased fuel. When I start to bog down a little going up the hill I am dragging I have to remember to actually ease up on the pedal of the HST. Just one more thing to add to the pulling power mix.
I myself far prefer HST despite it's shortcomings.
/ How does an HST compare in pulling power with the same tractor and a gear trans? #86
I think a lot of the answers are for this question.
Go push up against a tree (NOT recommended, but people do it, including me) with the intent to push that tree over. I have done it with both types of tractors. I have owned 3 gear and 2 hydro tractors. I can tell you which one I prefer. The Hydro hands down. Why? you ask. Because you can apply the force gradually without wheelspin and without clutch wear. The tree does NOT start to shake back and forth and has less tendency to drop limbs on your hood. That's why. Which one do I prefer for gently getting a pallet out of the bed of your expensive pickup truck with your pallet forks? Yeah, the hydro wins hands down. Going slow and applying power gently is hydro territory. Plowing ground and getting maximum fuel efficiency, is gear territory all the way.
/ How does an HST compare in pulling power with the same tractor and a gear trans? #87
I believe it's because they are looking at fuel efficiency...
It's a big deal when you are burning as much as they do.
SR
/ How does an HST compare in pulling power with the same tractor and a gear trans? #88
It's also whatever the current "TREND" is. Don't look at cost of ownership of various techological disasters, just fuel consumption figures.
/ How does an HST compare in pulling power with the same tractor and a gear trans? #89
Messicks did a video of two identical tractors with the exception that one was a gear and one was a hydro and the gear outpulled the hydro by a significant amount. Neil used a strain gauge hooked to a giant concrete block buried in the ground and both tractors had R1 tires on them.
Tractor Pulling Test - Gear Drive VS Hydro-static - YouTube
/ How does an HST compare in pulling power with the same tractor and a gear trans? #90
True.
But if you actually watch the video, good old Neil there put the hydro trans in high range for the test.
That is what K0ua was talking about in his first post.
Only a MORON would do that.
Put BOTH tractors in their lowest gear, or range, and it will be which one holds traction the longest. Which comes down to weight of machine and tread type of tires.
That's kind of the point.
/ How does an HST compare in pulling power with the same tractor and a gear trans? #91
What's the point of doing test on Low range or even use Low range as an argument? Everyone knows that any tractor with any transmission can do well in low range.
But, in the real world application, is a field plowed in Low range? Do you go on the road in low range? No...
Just bare tractor, no loader or implements, the HST will slow down significantly on a slight hill, where the Gear just keeps going at full speed. If the grade of the hill increases, the HST will most likely have to stop in the middle of the road to drop to Medium range and the Gear will just drop a gear or two on the move and keep going. There is your difference between the two transmissions.
Low range proves nothing other than that both transmissions can spin the wheels, unless that's a thing too...
PS: I have nothing against HST, in fact, would be the right transmission for my use but it would have to be special ordered at a much higher price tag.
/ How does an HST compare in pulling power with the same tractor and a gear trans? #92
The only thing I have against it is Neil from Messicks deliberately set up that "pull test" to fail.
If you're going to try to measure how much a tractor (any) can "pull" against a stationary object, you don't put it's trans in high range. That is just stupid.
What you're saying Ptsg, makes perfect sense to me, and I agree with you about climbing hills, etc. That's fine. And if that is what the "test" is supposed to show, then they need to do that specific "thing" during the test. But pointing to the HST opening up it's relief valve because some MORON put it in high range to pull against a fixed object as somehow is "proof" that a gear is better than a hydro is just plain silly, and insults the viewer's intelligence.
Hook both tractors up (one at a time) to a wagon pulling a load up a hill if that's what you want to "test". That's fine.
Intentionally tanking a "test" to somehow "prove" something just wastes everyone else's time, and makes the video producer look like an idiot.
Seems to me Messick's must have had a bunch of gear tractors on the lot they were trying to unload that month, and he needed some "help".
/ How does an HST compare in pulling power with the same tractor and a gear trans? #93
No need. There have already been Nebraska drawbar HP tests of identical tractors with HST and gear. Gear always higher HP to the wheels. Tested on dry pavement pulling test rig.
I guess if you need to pull a plow on pavement then gear is the way to go. All kidding aside the fact is that almost everyone has different conditions. For me spinning tires is a much bigger issue than HP. Gear could get an extra 1000hp to the wheels but if they are going to spin then what's it matter. I've watched a friend with an old Ford gasser slam the front end on the ground after popping the clutch while trying to pull a log. He suddenly was looking at blue sky and in went the clutch. That lead to backing up slightly and trying a gain only to see sky. On my property he would have dug some holes.
To me the places where gears shine are too few to justify the downside of a geared tractor. I like gears. I like shifting. But even I have gave in to the power of an automatic transmission in cars. Sure a geared vehicle is going to get better fuel economy but there's things like hill starts, parking, etc that life throws at you. I'll buy an extra few HPs and burn some more diesel to be able to use the loader on my tractor without having to deal with a clutch.
/ How does an HST compare in pulling power with the same tractor and a gear trans? #94
It would be nice to see that messicks test repeated with both tractors in lowest gear setting so we could have a better picture of the HST performance at both ends of the curve.
Another factor that comes into play in this video with the gear transmission is torque rise as the engine slows down. The HST transmission goes into relief before that rise happens in High range.
/ How does an HST compare in pulling power with the same tractor and a gear trans? #95
Nebraska tractor tests and similar European controlled condition testing are intended to answer the exact question the OP posed. If you want to change the question then the test conditions may have to change as well.
/ How does an HST compare in pulling power with the same tractor and a gear trans? #96
It's like the comment about tractor pulls. At a tractor pull there's equipment that grades and compacts the tract after each pull. It's done so each puller has the same conditions. My point is that we don't all live on a tractor pulling track and the question shouldn't be "which one can pull more" but "which one is right for the tasks I plan on doing".
/ How does an HST compare in pulling power with the same tractor and a gear trans? #97
Any way you slice or dice it the HST will always have less torque available to the wheels.
/ How does an HST compare in pulling power with the same tractor and a gear trans? #98
I do wonder if those new Branson tractors with 4 Range hydrostatic transmissions, will benefit from the 4 range to make up for that slight loss in efficiency.
/ How does an HST compare in pulling power with the same tractor and a gear trans? #99
True.
Good ole Neil had a glut of gear tractors to sell that month. That is all I can figure. No one with a brain would put a hydro tractor in Hi range for a pull test. That was very duplicitous.
/ How does an HST compare in pulling power with the same tractor and a gear trans? #100
Now you are on to something.
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59230)
International...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A61306)
PENDING SELLER...
2018 Ram 1500 4x4 Crew Cab Pickup Truck (A59230)
2018 Ram 1500 4x4...
2015 Ram 1500 4x4 Crew Cab Pickup Truck (A59230)
2015 Ram 1500 4x4...
2014 JCB 930 (A53317)
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
