How big or little - a SCUT...maybe a BX1880?
   / How big or little - a SCUT...maybe a BX1880? #1
DanThaTractorMan
Ijamsville, MD
none
I am new to this forum (and subcompact tractors) - what an amazing resource!
I may be typical of the reason that SCUTs have a booming market. I am only on 2.3 acres, about 60% wooded and 40% landscaped with beds, curves, and short (but somewhat steep) hills. A garden tractor with rear differential lock (to get up the hills) would cost a good bit...and mow the grass...and not much else.
So - my goals with a SCUT include mowing grass, transporting mulch and rocks, dragging logs and trash out of the woods (left by previous owner), plowing over old landscaped beds, uprooting bushes, and transporting heavy items around the property.
Some of the heavier work (or trickier work for me as a beginner) could include creating short swales to manage drainage, regrading and renewing an old 100-120 ft. gravel drive that is now overgrown, clearing a walking path in the woods, and possibly creating a short gravel connector (40-50 ft.) through the lawn between the main asphalt drive and the old gravel drive.
I would say most the grading work is not overly involved - generally more like tweaking here and there and then putting down gravel on the drive. Taking an inch or two off the crown of a short hill and packing the dirt a few feet away at the bottom.
Implements I am putting into the budget: pallet forks, a tooth blade, box scraper, and a landscape rake.
Now the question: how much tractor do I need to accomplish the above? (Or, what might I not be able to do with a smaller SCUT?)
I have looked at everything from a BX1880 to a JD 1025r, focusing mostly on tractors in the 22-23hp range.
That said, the price is nicer for the BX1880 (!), and the threads on TBN from happy 1880 owners (and a few Yt videos) are promising...those seem like very capable machines. What I am not able to tell from driving a tractor around a dealer parking lot (!) is how a BX1880 would do with a box scraper on a gravel driveway...or smoothing a path through the woods. If it is sufficient, great. If not, what size SCUT would you be looking at? Would I be in the ballpark with a machine in the 22-23hp range?
Thanks in advance for your thoughts!
   / How big or little - a SCUT...maybe a BX1880? #2
I'd say the 18 is too light.
I've done much of that with mine. The backhoe has been quite useful.
   / How big or little - a SCUT...maybe a BX1880? #3
In the past I have used a Kubota B7100 hst for the same jobs you have mentioned. At 16 horsepower it handled all the work. Sometimes slowly but it got it done. It was working on 68 acres rotatilling, Moving dirt, making an 1/2 mile access road, moving larger rocks, and skidding out trees.
   / How big or little - a SCUT...maybe a BX1880? #4
I think you'd be fine, as long as the implements you select are sized to the tractor you have.
It may take longer, due to taking smaller "bites" out of things, but it's not like you're working a couple hundred acres here.
Diggin It, would love the backhoe!
A question for you re: your MT125... I am seeing on the boards that lots of people really like their LS MT125s...I test drove one about an hour away, hoping that would be the ticket...this particular tractor had a lot of harsh vibration...is that common, or perhaps this one had a bad setup or broken engine mount or something? It looks like a great tractor... very solid and well-built...!
Egon, 68 acres! That is awesome - thx for the input.
   / How big or little - a SCUT...maybe a BX1880? #8
As I've read here, all/most three bangers have the shakes at some RPMs. When I get up to or near 'pto' speed of 2900, it runs pretty smooth. Generally above 2,000 is OK. The shakes come back quite a bit when I throttle down to 1400 or below before shutdown.
That was probably it - thanks! Wish the LS dealer was closer - nice machines....
   / How big or little - a SCUT...maybe a BX1880? #10
I accomplished most of your listed tasks with an old B8200 19hp and 2wd. Just takes longer than with a larger machine. Since your list includes pallet forks and moving large objects, I would look at the loader specs of the machines you are considering. People frequently over estimate just what they can lift with a FEL.
2022 Ford F-450 Liftmoore Crane Service Truck (A59230)
2022 Ford F-450...
TANK MANIFOLD (A58214)
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
Toro hr:2213.5 (A56859)
Toro hr:2213.5...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
