Un-Threading Brass in Brass Pipe Threads
/ Un-Threading Brass in Brass Pipe Threads #1
Tractor Seabee
Elite Member
Port Orchard WA Kitsap Peninsula, West of Seattle
Kubota BX25
I'm have reached an impasse trying to unthread a non-operative brass gauge from the brass housing of an oxygen regulator. First it is doubly difficult as there is not a good way to mount such gauges in a vise. It is a 1/4" pipe thread. I have used several type penetrating oil and as mush force as a 9/16 wrench with a cheater pipe with no yield. They must make these up dry and distort the threads.
Anyone have any bright ideas short of drilling it and rethreading? Barring any workable ideas that is my last resort. I am at my wits end with this. The regulator is Harris and worth fixing. Over the years I have replaced a lot of these gauges on regulators.
Ron
/ Un-Threading Brass in Brass Pipe Threads #2
Anyway to use heat/cold to persuade?
/ Un-Threading Brass in Brass Pipe Threads #3
As I understand your description you have brass on brass. These fo not corrode. Unfortunately, I have experienced people doing many crazy things to create a seal on the threads.
Some of the worst for future removal is red thread lock. If this is the case heat is the only thing I know to suggest to break that bond. It will need to get pretty hot and may need more than 1 heat cycle.
Another one us over tightening the joint. Sometimes these can be loosened with either a vice, using 2 wrenches (pipe wrenches) with cheaters. Heat application may also help.
/ Un-Threading Brass in Brass Pipe Threads #4
IF regulator body has large hex area on back side it is for actually mount body in vice.... Was informed of this by repair shop....
If you can anchor regulator body you can deal with gauge easier....
Gauge is probably over tightened, they spin them down to a point tapered thread do not leak and gauge faces correct way.... My regulators did not have thread locker but had devil of a time to change the tank connector on acetylene regulator...
Or....
Regulator and Torch Exchange, Inc. Regulator and torch repair, parts, and service.
These people supplied new diaphragm kits for my Victor regulators, and when I got stuck they answered my email questions........
Dale
/ Un-Threading Brass in Brass Pipe Threads #6
I was thinking the diaphragm, etc. would be out with just the shell left...
Dry Ice has saved me a few times and having free access to it helps.
That is an idea. Have to shrink just the base of the gauge as freezing the body would make it shrink and get worse, but maybe freeze and thaw several times. I will get some dry ice tomorrow. Makes me think, I have a cylinder of CO2, turn upside down and you get liquid.
Ron
/ Un-Threading Brass in Brass Pipe Threads #8
Put it in the freezer in the house over night. In the morning, put a right size spanner in boiling water and let it get as hot as you can hold with a rag. When your ready get the thing in the vice as quick as you can, then a good steady pressure using you hot spanner. Good luck.
/ Un-Threading Brass in Brass Pipe Threads #9
Think you concept of how expansion and contraction of heat and cold is backwards to the actual science....
Dale
/ Un-Threading Brass in Brass Pipe Threads #10
Careful. Oxygen and oil don’t mix. Explosive combination. Maybe why no thread sealant was used and tightened securely. Once you have used oil it is difficult to clean.
Thermocycling might work. They make a can spray that cools to break connections.
Be sure to use oxygen specific gauges.
Local welding supply could tell you if your regulator is worth rebuilding or replacing. May give tips on how they replaces gauges. They can rebuild torch seals too.
Sadly a lot of cheaply made sets now aren’t worth maintaining. Even some quality brands have cheap sets to compete. Smith brand use to give lifetime warranty. You can readily see and feel the difference of quality regular and gauges made to be serviced. You have the smarts and experience to make good decisions.
/ Un-Threading Brass in Brass Pipe Threads #11
Not a good idea due to the internals of the regulator especially the diaphragm.
Ron
Totally agree, but when it is useless in current state, do you replace some parts or trash everything?
Minimum price here for repairs to regulators is $70 plus 10% tax. Talked to their repair guy and he stated some of the treads are very difficult unless you have a special vice for holding regulators. Also they do not recommend repairing other than the high end ones. The little guy is priced out of the high end market with all the knock offs around. I can buy used name brand regulators cheaper than the repair. My time is my own so I may just drill it out. Tried all the thermal shock ideas you guys have to no avail. I am well aware of the oil situation, use only non oil sealants. Thans all for your ideas.
Ron
/ Un-Threading Brass in Brass Pipe Threads #14
Vibration sometimes helps. I would try an air ratchet with a crowfoot wrench. Don't let it rotate, but apply enough force to stall it in one position.
Bruce
/ Un-Threading Brass in Brass Pipe Threads #15
Im pulling for you...
When I had trouble changing out regulator oxygen fitting to tank a retired gas plant guy said to screw it in tight to the large cylinder first so as to use the cylinder as my vise.... it work and avoided visegrip marks on the brass
/ Un-Threading Brass in Brass Pipe Threads #16
Could it be... wait for it... left hand thread? Are the hexes notched on the edges?
/ Un-Threading Brass in Brass Pipe Threads #17
Probably not almost all US made gauge bodies use 1/4 inch NPT.... Even the acetylene body is 1/4 inch pipe thread, it just uses a nipple on outlet that is 1/4 inch NPT on one end and 9/16 X 18 UNF LEFT HAND thread for hose connect...
Dale
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
2022 New Holland C327 Compact Track Loader (A63118)
2022 New Holland...
UNUSED KJ 20' BI PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20' BI...
250 GALLON FUEL TANK W/HAND PUMP (A62131)
250 GALLON FUEL...
John Deere 5075E Tractor w/ John Deere 520M Loader (A64047)
John Deere 5075E...
2012 BMW 328i Coupe (A61569)
2012 BMW 328i...
