3-Point Hitch Quick Hitch Trouble
/ Quick Hitch Trouble #1
GoldenAcres
Outside of Charlotte, NC
Bobcat CT2040
I just picked up a Bobcat ballast box for my CT2040. When I got it home and went to hook it up, the top hook barely made contact with the top bracket.
I tried adjusting the top link some, and fiddled with it for a while, but it produced the same result time and time again.
Anyone know what I’m doing wrong?
/ Quick Hitch Trouble #2
Looks like the top hook needs to be moved up...
I thought that, too, but it’s set for my bush hog (also Bobcat brand). Surely I wouldn’t need to adjust the top hook depending on the implement, right? Especially if they are same brand?
/ Quick Hitch Trouble #4
I don't think bobcat makes them, So different measurements from the manufactures..
/ Quick Hitch Trouble #7
Looks like your QH is setup for Cat-1 and your box is Cat-2. Your other implements are most likely Cat-1 also if they fit that QH. You should buy or make all your attachments fit the QH. That's what it's for--That's why it's called a quick hitch. ;)
I went through the process of "fixing" my attachments when I got my QH. It started with my rotary mower. It was Cat-2 so that's what I set the top hook to and life was good. I picked up a flail mower at an auction and it was setup for Cat-1. It was an easy fix for that since all I had to do was move the top pin to the upper holes. (The holes were already there.) My plow was already Cat-2 and the disks use a draw bar. Oh yeah, I had to drill new holes in my trailer ball hitch since I built it before I got the QH. I'm looking at tillers now. If I get one, it will be a Cat-2 or be "convertible". Most new equipment now days is. :thumbsup:
Thanks, all. I was naive thinking it would all work "out of the box."
My rotary mower is tricky to get on / off. Really need to tilt the top link back. Kind of makes me wish I went for the hydraulic arms...but, hey, still faster than not having the quick hitch. I have a set of Cat 1 bushings on the way (everyone around here is out of them, it seems). I'm also going to try that broader hook that Peter 315 suggested. I need to do a mod anyway; adding a hook to it to hold the PTO shaft up when not in use. I guess I have a lot of "fixing" to do before I even get started!
Thanks agin, all.
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2025 Pabreak 74in. Hydraulic Dual Cylinder 4-in-1 Bucket Skid Steer Attachment (A61567)
2025 Pabreak 74in...
PUMP (A60736)
PUMP (A60736)
Honda utv cart (A56859)
Honda utv cart...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
Truck Mounted Carpet Cleaning Extraction Machine (A61166)
Truck Mounted...
