Kubota 2000 M4900 engine problem(s)
/ Kubota 2000 M4900 engine problem(s) #1
tstex
Alleyton, Texas; Houston, TX
1997 Kubota M5400S
Hello to All,
My brother has a 2000 M4900 w about 1050 hrs. When he started it 3 days ago, he said there was a loud "breaking noise" and he immediately turned it off. The dealer came out to pick it up and the driver [that works on engines] said "a possible valve spring or injector cap..." He wouldn't comment further. My brother did not try starting it again. He's very mechanically inclined, but just doesn't have the space, tools and other to take it apart.
Does anyone have an idea of what might have taken place? If you have specific questions, I will ask him. I really appreciate your feedback and help.
Thanks again,
tstex
/ Kubota 2000 M4900 engine problem(s) #2
No idea what the noise is - but FWIW the 5-cylinder F2803 engine is known to have high build-quality and is very reliable (I've had 3) . It's been used since 1984 in several tractor models and many industrial power plants. Your brother did the right thing to shut it off. Even the most bullet-proof machine (which this is an example of) can have a rare problem. Hope this is not serious. Keep us posted. Take care, Dick B
Thank you very much Dick - appreciate the feedback. I know w my description was pretty tough to interpret.
The dealership is at least 5 days out before they can even look at it, and that was before they told my brother it would be 3-5 days before they could pick up the tractor. At least it's good to know some businesses are booming...hopefully it's more routine maintenance work rather than engine overhauls...stay safe, tstex
The dealer attributed the breaking sound to a fuel-injector imploding, due to contaminated fuel. I have never heard this, but they are having to replace 1 fuel injector, cleaning out the fuel tank, fuel lines and all other f-injectors.
My brother buys 5 gal containers of diesel, then fills the tank. He can only attribute the bad fuel to the time his nearby brother in law used his tractor, then refueled it from his standing fuel tank. He also filled 1 5gal container and when my brother was using that, he stopped when it got down to 1/4 of the container bc he noticed "s\a sludge" started coming out. He never runs the tractor to a low fuel level, but his wife did...that must have picked up the bad fuel...
Moral of story: don't lend out your tractor or allow unmanaged fuel sources to be introduced into your tractor; make sure your wife knows how to fill-up the tank at 1/4 tank...
/ Kubota 2000 M4900 engine problem(s) #6
In my 50+ yrs of association with diesel powered farm equipment I've witnessed people putting fuel in fuel tanks in many different methods from different type containers. If M4900 had common rail/higher pressure fuel system I might believe your dealers theory(story) but I find this difficult to believe on the older style lower pressure fuel injection system such as M4900 possesses. I wonder what your dealer thinks the fuel contaminant was?? Was this tractors fuel system filter by-passed?
/ Kubota 2000 M4900 engine problem(s) #7
tstex
also...equip tend to last longer w/single owner use hopefully easy fix
"In my 50+ yrs of association with diesel powered farm equipment I've witnessed people putting fuel in fuel tanks in many different methods from different type containers. If M4900 had common rail/higher pressure fuel system I might believe your dealers theory(story) but I find this difficult to believe on the older style lower pressure fuel injection system such as M4900 possesses. I wonder what your dealer thinks the fuel contaminant was?? Was this tractors fuel system filter by-passed?"
Thanks Jim. I have no idea if the fuel filter was bypassed or other...I am passing on what my brother was told by the dealer...I will forward your note and see if he can determine the answer to your question. Thanks too B Bubba
regards, tstex
/ Kubota 2000 M4900 engine problem(s) #9
Water in the fuel will cause injector tip breakage. If the tip broke in a wat that caused a breaking sound, it would appear the tip went into the cylinder. They can be difficult to get out. Is the dealer certain part of the injector is not still inside? I’ve heard mechanics say the moved engine to top of compression stroke (both valves closed) then inserted a compressed air wand into the cylinder to blow the failed tip out. Air rushing out the opening takes the tip with it. If you Google broken diesel injectors contaminated fuel you will find a lot of hits for all manufacturers.
Thanks Harry, very interesting...I'll ask my brother to determine if the dealer found the broken tip - tstex
UPDATE: My brother said the dealer did not state the contaminate in specific terms. The fuel filter will be replaced and the canister cleaned...
Here's a few more updates and some sensible tips from one of the dealer mechanics.
First, the contaminate was just water. They tested the other 4 fuel injectors and said they call came back w a "weak-rating". So they're replacing all 5 of them, these 4 and of course the broken one.
Next, the mechanic stated that many times if you do not run your tractor daily or quite often, and at the the same time leave the tank 1/2 empty or less, condensation can form inside the tank. He said to top-off the tank as often as possible especially when you're going to be gone for any extended period of time. The same w the 5-gal diesel containers. He also said to make sure you check [and empty] your glass fuel filter canister if there's any water inside. In the instance with my brother, his wife [a country girl, my bro & 5 other siblings are from the city] ran the tractor and ran the fuel level down real low, going up and down slopes...probably stirred up some XXXX that was injected into the fuel system...
Going to cost him $1100-$1200 in labor $200/injector...the injectors are on order and like anything else these days, might take awhile...**** pandemic gets you coming and going...
Hope this helps someone....anything else of consequence that surfaces, I'll post back.
thank you guys,
tstex
/ Kubota 2000 M4900 engine problem(s) #12
Don’t know the filtration on your tractor but my Kubotas increase filtration with $$$ of the tractor. My M7 has 4 filters including coarse and fine water separators. The second water separator has a sensor (very basic - float that floats on water but not on fuel rises up and make contact when water in the bowl reaches a certain level). I have water separators on my 2 pumps and go through a lot of fuel, but water is still a problem. Two weeks ago my M7 engine derate, showed an error code “Low fuel rail pressure”. Indicator never showed, no water visible in the bowls of the 2 separators, but changing the element on the second got me back to full power. 285 hours since last change - book recommends changing every 400 hours.
Story on water in fuel. At Cat I had a customer in Saudi Arabia with 47 of one machine in my group. Failed injection pumps on 19 of them. Pictures they sent showed internal injection pump parts rusty - parts that should be living in diesel fuel. Had locals do investigation. Customer was using low price/low quality fuel smuggled at night from Iran. No way to stop that and a customer that can buy 47 machines of one model - and who knows how much other Cat equipment - gets treated well. So we developed a special “Middle East” second fuel separator, which involved an additional electric lift pump, to accommodate customers in the region. Fuel smuggling was so common we made it standard equipment for units sold there and retrofitted everything already sold.
Thank you MHarry...My brother has a M4900 Kubota, bought 2000 new, and I have a M5400S, bought 1995 new. Do you have any recommendations on fuel filtering devices that one can retrofit for our tractors? As of now, our sole line of defense is a fuel filter/bowl on the tractor.
In Minn, you have much greater temp swings as opposed to SE Texas. Are there any fuel additives that help? I like the idea of topping off the tank bc that does indeed eliminate condensation. However, I would also prefer something w in the fuel system that could indicate water is present. if possible. Anyone that has a suggestion would be appreciated.
Thanks
tstex
/ Kubota 2000 M4900 engine problem(s) #14
My advice from living in Texas operating tractors for over 50 yrs especially on Kubota & Ford tractors equipped with water seperater filter is check this WSF every time you check engine oil level. If water is present clean separater, drain water from tank & add fuel conditioner with biocide. As previously mentioned keeping tank full helps eliminate condensation. I've had water in fuel on all 3 of my tractors fuel systems due to faulty fuel storage tank with no adverse affects. I just correct problem by removing water then continue to cut/rake/bale hay.
On the other hand my neighbor with a M8560 tractor that has common rail fuel system got water in his tractors fuel tank. A fungus grew in the water & local Kubota dealer had to replace IP & inj's for high $$$$$$
THanks Jim / what type of biocide do you add that isn't a large portion of water itself and how much per gallon of diesel?
/ Kubota 2000 M4900 engine problem(s) #16
Adding an additional water separator is not straight forward. Injection pumps often have a lift pump feeding them. They might not be able to handle extra restriction. And adding a separator between the lift pump and injection pump may cause problems. The case I described required replacing the original lift pump with one capable of handling the added restriction. The filter media needs to be capable of withstanding the lift pressure. And water separators are capable of separating about 95% of the water so some is still going to get through, hopefully not enough to damage the system, the reason to use good fuel and do things like keep the fuel tank filled reducing the condensation problem. I have 2 100 gallon tanks on a trailer each having a Goldenrod water separator. Despite keeping a limited amount of fuel on hand, I often need to change separator elements as frequently as 2 tank refills (and I have used up to 400 gallons weekly this summer). At least I have kept that water out of the tanks of my tractors, CTL, and combine. I’ve also switched to using on-highway diesel despite paying road tax because I found I go a lot longer between replacing water separator elements. That also means I don’t need to make a special trip to fill my diesel pickup if I run low.
Great point M Harry...as you stated, adding anything will change the fuel system dynamics and that can wreak havoc fuel delivery.
Think I値l just stick to the basics of using good fuel, keep the tank filled and empty the fuel bowl much more regularly, esp when we have huge temperature swings. Houston had a temp of 85 & humid in December on yr, then a cold front popped thru and took us to 31 degrees. A day or so later it was in the high 60痴 lo 70痴...being so close to the coast the humidity can be 85-90% as well. Thanks for your feedback
/ Kubota 2000 M4900 engine problem(s) #18
I'm with Jim. Keep the fuel tanks full at all times when sitting, add a good biocide like Power Kleen and in my case up here in the north country a cold weather diesel additive like Powerservice helps with fuel not gelling. I store my fuel in 500 Gallon bulk tank and that gets treated with biocide every time it gets filled and a gallon of Powerservice too.
6K hours on one tractor, 2500 on the other and the 6 went into the Kubota shop for a tune up and valve lash adjustment early last year and they pulled and checked the injectors and all was good. Had them put it on the dyno and it's making 91 pto. Supposed to be 81 so either it's running good or Kubota under rates their engine power.
/ Kubota 2000 M4900 engine problem(s) #19
I also utilize power service fuel conditioner. IMHO a very important thing to do especially if water has been located in tractor fuel system is ""regular monitoring/inspecting water seperater bowl"" in lieu of operating tractor until presence of water causes engine to stop operating.
2018 DRAGON  130BBL VACUUM TRAILER (A65643)
2018 DRAGON...
Hays LT1 Tender (A61307)
Hays LT1 Tender...
2018 SHERP PRO1000 AMPHIBIOUS ALL TERRAIN VEHICLE (A63276)
2018 SHERP PRO1000...
Bobcat Pallet Forks (A64127)
Bobcat Pallet...
RoGator RG1100C (A63688)
RoGator RG1100C...
16ft T/A Utility Trailer (A64557)
16ft T/A Utility...
