What am I Missing? 1991 Ford F-350 hood latch
/ What am I Missing? 1991 Ford F-350 hood latch #1
Doofy
Super Member
Alaska
LS XR 3135HC
I am at Wits end, or maybe just Half-Wits end but I can't figure this out. 1991 Ford F-350: The hood won't latch and I can't tell if I'm missing a part of not.
I've spent hours on the internet and pouring through old Motors Manuals and can't find a single picture of the underside of the hood, to see what is supposed to be there. The latching part down by the radiator is fine.
Any photos or diagrams would be much appreciated. Thanks.
/ What am I Missing? 1991 Ford F-350 hood latch #2
I think you are just missing some WD40? lol
I think I am missing the "Striker". That flat bar in the photo is springy and just helps pop the hood up when the hood release is pulled. I only see one hole up there to mount something else. Odd.
/ What am I Missing? 1991 Ford F-350 hood latch #4
Did it work one day, and not the next or is there a "story"?
It's on my plow truck. I bought it in 06 and it never has latched. I never thought much about it because the truck isn't registered or tagged for highway use. I was fixing small things and thought I would fix that too.
/ What am I Missing? 1991 Ford F-350 hood latch #6
I would just go to a wrecker and get a new one. Or a couple of bolts in each front corner with large wing nuts.
If I knew what I was looking for, I would just make one. Nearest wrecking yard is 130 miles away. I guess I could find an online yard. Evidently, you can't buy a "new" one.
/ What am I Missing? 1991 Ford F-350 hood latch #8
That thing is likely an assembly, stamped out and rivetted together. Never meant to be taken apart or serviced.
You are probably right. Hoping for a photo to better understand what I am looking for. If not, maybe a hasp and a padlock.:shocked:
/ What am I Missing? 1991 Ford F-350 hood latch #10
Workd for Mr. Bean.
2013 Bobcat A770 (A60462)
2013 Bobcat A770...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A58214)
2018 PJ TRAILER...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
2013 Audi A4 Sedan (A55853)
2013 Audi A4 Sedan...
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
2022 Case SV280 (A60462)
2022 Case SV280...
