Thinking about a new Gooseneck trailer
/ Thinking about a new Gooseneck trailer #21
You Sir, are an exception. :)
But that trailer by itself is a good load on a pickup. It’s over 1000 pounds on the hitch empty. There’s no way I’d pull it with much of a load behind a ton truck. I’ve hauled a full size backhoe on a 10 ton GN behind a ton dually and it worked pretty good.
You have to have a WIDE approach at the end of your driveway for a 30' GN.
Even though its only 8' longer the simple fact that its a GN is a game changer. It cuts corners WAY shorter and doesnt track the truck as well as a BP when making a tight turn.
Everyone always says GN trailers are more maneuverable....well....yes and no. You can turn a GN around in a much tighter spot with being able to jackknife.....sure. But if you got a standard driveway made for car and truck traffic.....where a bumper pull would follow you in the drive nicely.....a GN is gonna be off the drive turning in. Which is bad if you have a road ditch, and culverts, etc.
For a standard rural road, you really need a driveway approach as wide as the trailer is long. Otherwise the trailer tires or the truck tires are gonna be off the driveway
Thank you for pointing that out. I was worried about the hunting land, and may not even be able to get in and out of my driveway. Trees on one side and a water meter on the other. Will have to do some measuring before I go any further. I have had no trouble with a 28' camper, but I knew the gooseneck would be different.
/ Thinking about a new Gooseneck trailer #23
was the camper 5th wheel or BP
/ Thinking about a new Gooseneck trailer #24
Ok, I do a lot of trailer pulling, being a truck driver by trade. I own an F350 with a gooseneck 20 plus 5 Big Tex trailer. I typically don't compare the trailers that I pull behind my F350 because they are so much smaller than the 53 and 57 foot trailers I pull in my work. While reading these posts, when I read the first one saying a bumper pull trailer would corner better than a gooseneck, it made me wonder. Then another agreed with him, so it made me question my own thoughts. Geometry is what controls the turning radius of a trailer. The distance the axles are from the rear axle on the truck is what controls the turning radius. Now, if you put 2 identical trucks with the axles exactly in line with each other, will one corner better than the other? I have my doubts, but am willing to be open about that. Now, what I do know, if I am putting either a bumper pull, or a gooseneck into a really tight area, with the bumper pull, I am restricted by just how far I can jack-knife the trailer, such as in making a U-turn, by the tongue of the trailer. Jack-knife a bumper pull trailer too far and you have bent tongues, twisted couplings, bent truck bumpers, etc. With the gooseneck, I can literally turn my truck to almost a 90 degree angle from the trailer allowing me to turn a whole lot tighter. If I need to turn into a really tight driveway, I go past it with my truck, and then jack-knife the truck into a 90 degree position and then pull into the driveway. I can't do that with a bumper pull, it would bend the bumper, etc. Without going out and buying 2 separate identical trailers, there is almost no way for me to make this decision, but I do know that if I were in the market for a new/used trailer, I would take my truck to a trailer place, and hook to both styles! Have someone stand by the hitch as you maneuver it to make sure you don't run into the "you break it, you bought it"!
I sure hope I didn't step on any toes!!
David from jax
/ Thinking about a new Gooseneck trailer #25
David from jax
Everyone knows you can back the truck at a sharper angle with a GN. But how useful is that? Semis do it all the time but what about pickups and smaller trailers. I don’t recall ever having done that with a GN trailer. I don’t have any proof either because I don’t own 2 identical trucks and trailers but I know for a fact I can circle my 6500 truck with my 24’ trailer in a tighter circle than I could my 25” GN and a pickup. I can back my ton truck or suburban and 20’ trailer out of most driveways onto the road without backing off the other side of the road. I couldn’t come close to doing that with my GN trailer.
/ Thinking about a new Gooseneck trailer #26
Gooseneck trailers also have a tighter turn radius. This lets you cut corners tighter than a bumper pull trailer and lets you maneuver the trailer in tighter spaces. This tight turn radius can be a double-edged sword, though. It takes a few tries to learn, and if you mess up you can take off the trailer’s fender, to say nothing of damaging street signs and other cars on the road.
This quote was from Featherlite Trailer website (Bumper Pull Trailers vs. Gooseneck Trailers | Featherlite.)
4570man, I understand your point of view, and it would be interesting to know what the two vehicles turning radius is, without a trailer. A lot of times the wheelbase and the amount that the wheels will actually turn has a lot to do with it. I had issues with a semi truck not being able to turn into my driveway without the trailer hitting the end of the culvert, and my crewleader told me to remove the bolt stops which would allow me to turn tighter. I drove another one that had them removed, and decided that I just needed to slow down a little more before turning into my driveway, which worked. For liability reasons, I did not want to be the one that actually removed a factory installed part. There are simple reasons for what we both "know", and I applaud you for discussing it opening.
I would be interesting in seeing a picture (or the measurements) of the 6500 with trailer and the 1 ton sitting side by side. Where do the trailer axles actually fall? Bumper pull trailers "typically" have the axles further forward to reduce tongue weight, whereas a GN is designed to put more on the tongue because the weight is partially split with the front axle of the tow vehicle. Shorter wheelbase definitely makes a difference and is easy to miss when just pulling different trailers with different vehicles. I have a gun nut friend who has a bumper pull trailer, 20 plus 3 I think, and my 20 plus 5 should be very close, but for my thoughts, I think his axles are way more forward than mine are.
David from jax
/ Thinking about a new Gooseneck trailer #27
David from jax
Its abut the hitch point.
With a GN, the hitch is FORWARD of the rear axle. So the VERY MOMENT you start turning into a driveway....the Trailer starts heading the same direction.
With a BP, the hitch is several feet behind the rear axle. So you start a turn into a driveway....the trailer actually goes the opposite direction for a moment if you turn real sharp....and tracks much closer.
/ Thinking about a new Gooseneck trailer #28
David from jax
Here’s the 6500 and trailer. The one ton was a 4 door long bed GM truck. I don’t have the GN trailer anymore. But hitch weight wasn’t a concern for dump truck pintle trailers so the axels are pretty far back. The 6500 has a 10’ bed and the axel is almost at the back of the bed so I think the wheel base on the trucks would be pretty close. IMG_9079.JPGIMG_8703.JPG
/ Thinking about a new Gooseneck trailer #29
I just did some looking at Big Tex website, and compared GN and Bumper Pull trailers. I looked at 20 foot trailers, but unfortunately they don't offer the same bed size in both trailers. I did notice that it appears to go along with my thoughts that trailers with GN axles are further back, which would mean a longer turning radius, but the fact that the tongue allows for a closer turn, kind of evens out some of that.
David from jax
/ Thinking about a new Gooseneck trailer #30
David from jax
But how useful is that in a forward only turn? Can you cut the truck into the trailer going forward only with a BP trailer?
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
Mini Skid 6 Way Blade (A56438)
Mini Skid 6 Way...
Honda utv cart (A56859)
Honda utv cart...
(APPROX. 640BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 640BF)...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
Bobcat mid mount mower M60-5 60" CT2025
Bobcat mid mount...
