Thoughts on 5100m and 5115m loader tractors
   / Thoughts on 5100m and 5115m loader tractors
I have been reading as much as I can find on the Deere site, from there brochure the premium cab adds ; sunroof, radio,speakers , rear window wiper, floor mat in back of seat and couple other insignificant to me items. I took the time to use their Build your own page and that was really quite informative and interesting . That gave the base price for each model I looked at 5100m and 5115m , then showed all the options you could add and their respective list prices. The list base price for each 4wd , no cab , 66,000 and 71000 respectively . The 15 hp increase between the two about 5k, that was one thing I was curious about, now I know. Standard cab add 12,365 , premium cab add 14,122. Opened my eyes to all the options available and respective price. Only thing I couldn't make it do was add loader models available and prices. Came out with about 85k /5100 and 90k/5115 optioned my way. That included loader prep package but no loader. List prices are always sky high , makes you feel good when your salesman shows you a substantially lower sales price.
   / Thoughts on 5100m and 5115m loader tractors #12
Good job on using the "build your own" feature. It's very informative.
Print off the two tractors and then compare features to ensure you don't miss something. The option list also allows you to see what features are standard on each model.
I would have thought the 115 might have a size larger tire? How did the weight compare? This would tell you if there are some structural differences that didn't show up elsewhere.
It's been a few years since I used the JD site. My memory says there was some odd way you had to add the loader? Can't remember for sure but I figured it out. I was comparing the JD to a similar Kubota.
   / Thoughts on 5100m and 5115m loader tractors #13
540M loader with 85" bucket w/grapple added about $11k. My 5090E I got the air suspension seat. They didn't have a 5100 or I would have gotten it but the 5090 is the same tractor. I think that's basically the case with the 5100M and 5115M.
   / Thoughts on 5100m and 5115m loader tractors #14
Correct. The 5100M and 5115M are identical in every way except for engine tuning.
Thanks for the informative replys , all coincide with what I've read. I realize I need to go see one of these tractors at a JD dealer to really see if it fits with my needs, probably do that within a week. Got so many things to get done around the orchard before snow flies I hate to take a day to do it. One spec on the 540m/h260 nsl loader I'm not sure of is the Reach at ground level, reach at max height . Brochure says 101" & 41" respectively . No diagram to show where the measurements are coming from. I would of assumed both were measured from the nose/ grill to the lip of the bucket flat on ground and also lip of bucket with the bucket floor level at max height. My big concern is that 101" dimension , i can't believe from nose of grille to bucket lip flat on ground is that far and if it is manueuverability in tighter orchard situations may be an issue. I measured one of my 545d's , nose to bucket lip flat on ground right about 60". From the pictures it looks a little longer than my 545 but surely not almost 3 1/2 ft more. Does anyone know from where to where jd is obtaining these measurements? Or just as good tell me what this measurement is on your 5m. Thanks to all, B
   / Thoughts on 5100m and 5115m loader tractors #16
I will try and get you that measurement this weekend.
Thanks Ortimber but curiosity got the best of me and yesterday morn took a run to my closest jd dealer and got a look. They had two 5115m with no loader mounted and a 5100e w 540m mounted so took measurements off that. Bucket flat on ground front of grill to bucket lip 77" near as I could eyeball straight down to bucket lip. So that I think will work. I was still curious where there 101" reach spec was measured so I went from center of front axle to bucket lip, bingo 101". Took some time to look over one of the 5m they had, looks stout, standard cab , air seat , 3 rear remotes, manual levers for 3pt which I was I was very impressed with how easily they moved and short distance to move with finger tips. This was a 2018 w about 200hrs, had the 16 speed and tires were downsized from standard to 16.9 x 30 rears. Would of been more interested if it had the 32 speed and 18.4 x30. Overall like the 5m series and think it will fit w what I need it for. Just gonna try take my time and keep looking till I find the right one.
   / Thoughts on 5100m and 5115m loader tractors #18
You are right, the M series machines are stout. Like I mentioned earlier, I highly suggest you get a tractor that has the electro-hydraulic 3 point control and the 32 speed transmission. Good luck in your search!
2013 Dodge Durango Crew AWD SUV (A55853)
2013 Dodge Durango...
2017 FECON RTF140 HIGH PERFORMANCE MULCHER (A52705)
2017 FECON RTF140...
UNUSED 70PCS White Metal Roof Panels (A53117)
UNUSED 70PCS White...
(2) SQUIRREL CAGE FANS (A54757)
(2) SQUIRREL CAGE...
Honda EU3000is Gasoline Companion Inverter Generators (A54811)
Honda EU3000is...
1995 CATERPILLAR 928F WHEEL LOADER (A52707)
1995 CATERPILLAR...
