L45 forward hydraulics
/ L45 forward hydraulics #1
woody
Central Alabama
Kubota B26, Kubota ZG222, Kubota L45, 1980 Ford 1700
I have the Kubota brand forward Hydraulics and while using my sickle bar cutter today it appears the valve stuck because I have no control over it and when I took the hydraulic sickle mower off the tractor would not move very fast and the FEL and Backhoe will not move. it was late and I didn't have time to diagnose it but it seams to be dead heading. what should I be looking for? I do not have a parts or service book on the forward hydraulic system but it was installed by Kubota right after I purchased it a couple years ago and has work great until today.
What no comments, not even a question?
/ L45 forward hydraulics #3
Only 1 hour 8 minutes between your posts?
You are in a BIG hurry!!!!
first post yesterday at 8:02 PM, but I did correct a misspelled word this mourning. BUT my tractor is sick so yes I'm upset :shocked: :duh:
okay been out in the shop trying to figure something out but I just don't know!
when I crank the tractor I can tell it is under a load as soon as it cranks.
the FEL will not lift unless I press the 3rd function button at the same time. the dump and roll function works as always.
the backhoe does not lift unless I press the 3rd function button. but the swing works as it did before.
it seams to me like it has a hydraulic return to tank problem.
I called my local Kubota shop but they have not returned my call.
/ L45 forward hydraulics #6
Your first post wasn’t terribly clear about the problem. So the 3rd function valve stuck open meaning while the mower was attached it ran continuously without the ability to stop it?
/ L45 forward hydraulics #7
Sounds like a coupler got loose and won’t allow oil flow.
correct, and now I have disconnected the sickle mower and checked the 3rd function solenoids for proper magnetic functions so electrically I believe they are good.
okay I have not thought of that so back out to the shop I go. and while taking a ride on it just before I came in if I put the FEL in float and when I take it out the tractor speeds up for a second or two. :banghead:
I'm thinking now that the 3rd function valve leaked by because of the pressure not being relieved, to much pressure. I can hear the pressure relief/safety staying open when things are not working as they should.
your post made me think the first thing I thought of was the 3rd function valve but when I kept messing with it I talked myself out of that and into something else but then your comment sounded so logical. So I went out this mourning and tore apart the 3rd function valve but not knowing what I was looking for I took everything apart and noticed the small spool piece looked out of alignment to me. After taking it apart and cleaning, but not finding anything obvious I put it back together and by some strange merical the spool piece was lined up. so I put it all back together and it is working like it should. it may happen again the next time I use the 3rd function valve but for now it is working. Strange things happening all around.
2012 Ford F-350 Service Truck (A61568)
2012 Ford F-350...
2017 PETRBILT 389 6X4  T/A SLEEPER TRUCK TRACTOR (A59908)
2017 PETRBILT 389...
2017 Chevrolet Suburban SUV (A61569)
2017 Chevrolet...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
2007 PETERBILT 386 T/A 6X4 SLEEPER TRUCK TRACTOR (A59908)
2007 PETERBILT 386...
