3 cylinder vs 4 cylinder debate
   / 3 cylinder vs 4 cylinder debate #21
Interesting. I never knew that. Why is that? It's actually worse than that. They run at 3600 to make 60 hz.
   / 3 cylinder vs 4 cylinder debate #23
I think that this is a trick question. The number of cylinders doesn't have nearly as much to do with efficiency and smoothness of operation as do numerous other design factors. A certain three cylinder can be better that a certain 4 cylinder in these regards, while a different 4 cylinder can be better than that three cylinder. I agree all the answers you get her will be highly opinionated and non-factual.
There are some cylinder configurations that are naturally balanced. The others need some extra gear to run smoothly.
   / 3 cylinder vs 4 cylinder debate #24
Curious wht INDUSTIAL gensets run at 3000rpm and how the poles are arranged?
   / 3 cylinder vs 4 cylinder debate #25
You are going to see more difference between a 3 and 4 cylinder engine due to other design features than you are the number of cylinders. 3 and 4 cylinder engines aren't perfectly balanced and are all even-fire engines so they behave and sound fairly similar.
- An engine with a larger number of smaller cylinders will seem smoother than an engine with fewer larger cylinders and have a higher RPM where it achieves peak torque and power.
- Inline six cylinder engines are perfectly balanced and will seem much smoother than engines with fewer cylinders. Their cylinders can also be made enormous without the engine vibrating excessively, unlike engines with fewer cylinders.
- Crossplane V8s are nearly perfectly balanced and will be smooth as well, but have a very distinctive sound that immediately distinguishes them from essentially all other diesel engines out there, which are even-firing.
There is a reason the industrial gen sets run at 1800 RPM.
Yeah, they are coupled to a four-pole generator head and you want 60 Hz AC. A two-pole head requires 3600 RPM which is too fast for most diesel engines. A six-pole head requires 1200 RPM which is below the typical ideal operating range of most transportable diesel engines. You would rather not have to deal with speed-changing gears if you can help it, so 1800 RPM it is.
   / 3 cylinder vs 4 cylinder debate #26
The inline six is naturally balanced!
How about a boxer 4? Subaru 4!
   / 3 cylinder vs 4 cylinder debate #27
3 cylinder designs cancel out there own vibration without the need for balancing shafts. Plus they have alot less moving parts.
   / 3 cylinder vs 4 cylinder debate #28
Maybe for small engines but once into larger horsepowers three big cylinders banging gets harder to deal with vibration.
Our generators at work are v16 engines, we don’t have RPM gauges but I would assume they are cranking around 2000-2500RPM. Our are Caterpillar but a Detroit sounds like it’s going twice as fast as what it is so idk, it’s not the easiest to guess RPM lol.
   / 3 cylinder vs 4 cylinder debate #30
At idle, the 3 cyl Kubota D722, in my little Steiner, seems to want to jump right off it's rubber mounts! Too bad this litle engine is so rough. And a hard starter in the cold.
11' x 19' All Metal Carport (New/Unused) (A59225)
11' x 19' All...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2012 Ford Econoline Cargo Van (A56858)
2012 Ford...
2022 DODGE RAM 2500 SERVICE TRUCK (A58214)
2022 DODGE RAM...
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
