L3400 front axle noise
/ L3400 front axle noise #1
jenrow33
Michigan
Kubota L3400HST
My 2007 Kubota L3400HST (1125 hours) just developed a squeak at the left front wheel. It squeaks in sync with tire rotations (once per rotation). I see no fluid so I assume this isn’t seal related but wondering if it’s a bearing going bad. I use the loader regularly but never abused or overloaded it terribly.
Question is, has anyone rebuilt the front axle of a L3400 and if so, how difficult is this job? I’m pretty handy and thinking of just getting into it and doing the seals and whatever bearings look or feel bad. Thoughts?
/ L3400 front axle noise #2
Are the lug nuts tight....
Yes, checked the basics, lugs are right, there’s nothing wound around the wheel/axle, it’s clean-no dirt or debris. I’m thinking one of the bearings but it’s a dry squeak which doesn’t make sense for a bearing because they should be submersed in fluid if I understand the diagram right.... If I can figure out how, I will post a video clip of the sound.
/ L3400 front axle noise #5
Did you look close at the wheel for any cracks?
/ L3400 front axle noise #6
Check fluid level, and crack the bottom drain on that side and make sure fluid starts to run out. BUT, these wheel squeks always seem to be related to the wheels, Are the wheels width adjustable? Make sure EVERTHING is tight. Any chance it could be the axle pivot, never greased?
/ L3400 front axle noise #7
Step 2: Jack up tractor front end, spin tire/wheel by hand. See if you can figure where noise is coming from. Remove wheel. Spin hub by hand. We ARE assuming the tractor is 4wd correct? If it is 2WD, when was the last time you greased the hub. :)
Tractor is 4x4. I’ll have a video posted to YouTube and a link in a few hours.
/ L3400 front axle noise #9
Your question really pertains to how difficult to rebuild. My failures were a L5740 but I believe not too different in design from your tractor. It’s not a difficult job. My failures were noticing oil leaking onto the wheel. Raised the front using the loader and found wheel wobbled. Checked this site and learned it is a common issue if loader is used for extensive load and carry, which was the case for me. First you would want to make sure this is your problem but if it it is, it’s not difficult to repair yourself. My dealer, however, told me that one customer who uses his a lot for carrying large hay bales pops the unit off and brings to the dealer to rebuild.
So I have an update, went to remove the wheel lugs and one broke. Assume loose lugs or having one loose or cracked could be the issue. New lugs on order. Removed wheel and inspected the hub thoroughly and there doesn’t seem to be anything loose or leaking in any way. No squeaks with wheel off! Gonna try new lugs torqued to spec and see if that works. Thanks for all the input.
/ L3400 front axle noise #11
Please keep us posted... but kinda think you have found your problem.. hope so.
/ L3400 front axle noise #12
Seems to me if fluid looks good and you jack front end up, grab the tire at 12&6 and get no movement then bearings are good and it's something else.
Got everything tightened back up on the front tire and it seems to have fixed the noise. Checked the right side too and found two lugs looser than they should have been.
Gotta say, I’ve put 1100 hours in 12 years on this kubota L3400 and she runs like new still. I’m impressed with this machine. Each time I think I may have an issue, it’s been something simple. Pretty sure I can get another ten years out of her. Perhaps some hydraulics in the form of rear remotes and a third function kit are in order to expand the implement collection!
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
2016 Nissan Sentra Sedan. (A66738)
2016 Nissan Sentra...
Club Car Turf Carryall 252 (A64912)
Club Car Turf...
2023 Star EV Lithium Battery BI/Charger (A64912)
2023 Star EV...
2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
2023 Land Pride...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
