Bye, bye irritating turnbucles
/ Bye, bye irritating turnbucles #1
07wingnut
Clearwater, BC, CA
BX23
/ Bye, bye irritating turnbucles #2
Nice mod.
Ford made similar ones at one time.
Not all scenarios benefit from a rigid fixed lift arm position. Sometimes you want a little bit of travel hence the slot in photo.
/ Bye, bye irritating turnbucles #3
Give it time, you'll get irritated with these too. Sometimes I can't find the "just right" setting like you can always do with a turnbuckle. The Kubota ones have a non-uniform hole pattern that gives a lot of in-between settings, but it can take a few tries to suss that out sometimes.
Make sure you adjust these so that they check motion by going into tension, not compression. A lot of folks overlook that part.
/ Bye, bye irritating turnbucles #4
Ummmm, I didn't know turnbuckles was irritating I must of missed that meeting. To me a fixed pin position has the makings of to much not enough, now that would be irritating to me almost as bad as loosing a pin or bent pin.
/ Bye, bye irritating turnbucles #5
I was thinking the same thing, but thought it must be my inexperience.
/ Bye, bye irritating turnbucles #6
Mine has both, pins and turnbuckle. It also has a slotted pin position in case you need a bit of lateral travel.
/ Bye, bye irritating turnbucles #7
I had both on a number of tractors...
Didn’t know turn buckles were a pain in the rear til I got the first tractor without.
Never go the other direction.
/ Bye, bye irritating turnbucles #8
Yea, my 5310 had chain turnbuckles. They were a pain. Had to have a wrench all the time to tighten the locking nut and with some implements you just couldn't get to them.
Because the spacing of the holes on the inside slider is slightly different from the ones on the outside tube, very small incremental changes can be made to the lower link position by selecting the correct hole for the pin.
/ Bye, bye irritating turnbucles #10
I never checked the hole spacing on mine but that must be how they work. Standard on the LS i have and works well.
/ Bye, bye irritating turnbucles #11
The "pin in the hole" type are OEM on my Kubota M6040. They work just fine and are a bit quicker than the twist ones that came on my Ford.
/ Bye, bye irritating turnbucles #12
I agree, plus it doesn't come loose like the turnbuckle style.
This telescopic style come standard on most tractors these days.
I've never had any problem finding the right spot and it also prevents the lift arms from bouncing around and hitting the tires with no implement attached.
/ Bye, bye irritating turnbucles #13
Same with my MF 1540. Towards the tractor end, rather than individual holes, there is an elongated hole - maybe 3” long.
Never had any issues putting implements on or centering them.
/ Bye, bye irritating turnbucles #14
I've never had a problem with my turnbuckles or floppy lift arms. I have a QH. And the turnbuckles attach to the drop-down on the ROPS mount. Of course, I have more than 12" between my tires. :rolleyes:
/ Bye, bye irritating turnbucles #15
:thumbsup: Didn't know that, so thats how one can get just a little or a lot of adjustment, good info thanks!!!
/ Bye, bye irritating turnbucles #16
I'd think that it would be difficult to find holes in those that would keep the 3ph tight enough to keep it from swinging. With turnbuckles, you can just tighten them up (and you better; broke the 2 on my 4010 one time when I left them too loose).
Biggest problem with turnbuckles might be to lock them in place. I've only ever used tension cords from one side of them us to the tractor body somewhere.
Ralph
/ Bye, bye irritating turnbucles #17
Ralph
You don't really want it very tight. 3 PT is not a perfect linkage setup, quite often the pivot point for the stabilizers is not perfectly aligned with the pivot point for the lift arms. This causes it to bind in certain 3 pt height positions if the turnbuckles are too tight.
On mine with the telescopic style, I get about 1/4" of play and that's exactly how I like to run my 3 pt implements.
/ Bye, bye irritating turnbucles #18
The turnbuckles on my lower arms are lined up and I keep them snug if not my pto winch will slam back and forth on every bump, thats why I was questioning on how to keep implements from doing that on pinned lower arms.
/ Bye, bye irritating turnbucles #19
Those turnbuckles have a nut to lock the position on the right hand threads, correct?
Geez I hate having to word my posts without the use of contractions.
/ Bye, bye irritating turnbucles #20
My turnbuckles have lock nuts, I dont think they would stay in the right adjustment without them.
2020 KUBOTA SVL75-2 SKID STEER (A62129)
2020 KUBOTA...
(1) New 7ft Chain Sling (A61166)
(1) New 7ft Chain...
Cub Cadet Ultima ZT1 Zero Turn Mower (A64047)
Cub Cadet Ultima...
2026 Hillcrest Trailer 14166SPT 7 Ton T/A Partial Tilt Trailer (A61569)
2026 Hillcrest...
BUNDLE OF APRROX (20) 3'X30' METAL SHEETS (A62131)
BUNDLE OF APRROX...
Arrow Quip EF10 Two Bow Alley Kit (A64047)
Arrow Quip EF10...
