New Holland Workmaster 70 Problem
   / New Holland Workmaster 70 Problem #1
chfrich
Kioti CS2210
Still having problem where New Holland Workmaster 70 Tractor driveline seems to drag while tractor is in regen. Only lasts about 5 minutes or so. I cannot figure this issue out. Dealer says brakes are only thing that could do this. Brake linkages have been checked and lubricated several times. Drag on driveline ONLY occurs when tractor is in regen!
   / New Holland Workmaster 70 Problem #2
Is this something new or have you always noticed it during regen?
It was worst before software upgrade but still present during regen.
   / New Holland Workmaster 70 Problem #4
Not knowing a better answer for you it could just be the nature of the process. I would think it is more of a power loss than a drag on the driveline. I just don't see how regen could produce drag but I can see how it could reduce power. :confused3:
   / New Holland Workmaster 70 Problem #5
Exactly. There is no electronic control or inputs over any brake or driveline components.
During this event the tractor does not coast when depressing the clutch. Now I am wondering if something could be dragging internally in the transmission, rear differential or even a hydraulic pump problem?
2025 Swict 78in Bucket Skid Steer Attachment (A53421)
2025 Swict 78in...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2020 KOMATSU...
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
2010 Turfco...
