Cant separate 2-spline PTO shaft in order to cut it
   / Cant separate 2-spline PTO shaft in order to cut it #11
If your shaft is extending and closing easily untill it seems to hit a stop I would be leery of hitting it or pulling it with force.
I do not recall ever seeing a two spine pto shaft, how about some photos.
I have seen some old rectangular shafts that had a stop pin for extension,
the pin rode in a slot cut in the sides of the receiving rectangle.
I forgot to mention the rectangular with a stop pin was a while ago,
it was old enough to have a steel tube guard on it.
   / Cant separate 2-spline PTO shaft in order to cut it #12
PTO shaft was probably bottomed out at some point in it's life and the ends deformed a little. Catches on the deformed ends.
   / Cant separate 2-spline PTO shaft in order to cut it #13
I've never seen telescoping pto shafts that had a stop/catch to stop them from sliding apart. Maybe rust & dirt binding but not catch. Ditto on utilizing Kroil or PB Blaster
   / Cant separate 2-spline PTO shaft in order to cut it #14
I'm with you..... Probable been hammers to much in collapsed direction and ends of both inner and outer are deformed....
Dale
DING DING DING WINNER WINNER CHICKEN DINNER!
So, out of desperation I cut it to get it apart. And? It has a steel cable down the middle to keep it from extending too far. Sturdy too! We did use two trees and two comealongs with a fair amount of force, but it would not separate!
So, I cut it, and there's a CABLE in the middle. Is that common? Seems functional without the cable, and with it being used on a towed generator, there's no obvious way it would slide apart in use. I am going to continue working on this. I only now saw the newer replies. Thanks everyone. I will get pictures up.
Shared album - Ken Weston - Google Photos
We did all that work, but the shaft must be slightly damaged because it still won't compress enough. At first, it just wasn't possible, but even shortened it won't. It's a bit weird. I am looking for replacements now, but I will start a different thread I think.
   / Cant separate 2-spline PTO shaft in order to cut it #17
Very interesting. First time I've seen on a PTO shaft.
   / Cant separate 2-spline PTO shaft in order to cut it #18
Did you cut Both pieces off?
The inner slides inside but the outer has to be cut some also to allow the inner to travel in.
Don’t laugh. I’ve seen it more than once!
   / Cant separate 2-spline PTO shaft in order to cut it #19
Yepper 1st time I ever heard of/seen a cable limiting the length of extension of telescoping pto shafts.
   / Cant separate 2-spline PTO shaft in order to cut it #20
How does one secure a short cable like that cable inside a PTO shaft?
Obviously it was pretty well attached as the OP mentions applying a fair amount of force when attempting to pull the shaft apart.
1987 International S1900 Flat Bed Truck (RUNS)(TITLE) (A50775)
1987 International...
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A53422)
2014 Ford F-550...
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
2020 KUBOTA SVL95-2S SKID STEER (A52706)
2020 KUBOTA...
