Screw in front tire, no air leaking, should I worry about it?
   / Screw in front tire, no air leaking, should I worry about it?
I would put a small paint mark on the rim at the hole..
That way if, when it goes flat you know where to start looking..
Yep, I marked the rim with a Sharpie.
Haven't put a ton of hours on the tractor this week, but so far the tire is still holding air.
   / Screw in front tire, no air leaking, should I worry about it? #12
No rim mark required. Simply remember by the markings on the tire.
If you don't have one, buy a plug kit.
   / Screw in front tire, no air leaking, should I worry about it? #13
Interesting discussion,
I had one rear go darn close to flat when snow blowing.
Fortunately I had a can of air to inflate enough to get home where I kind of over inflated to continue.
That was 2 years ago and that tire never lost pressure since.
Tire is tubbed and filled with beet juice, might the juice plugged the hole?
Still wonder to this day if I have an actual puncture.
I speculate that perhaps a loose binder might have 'flicked' the valve to allow air out, that or slime did a plugging job.
Notice I took the 'let well enough alone' approach and simply monitor pressure from time to time.
That's going on 100 hours or so.
Fingers crossed.
Repairing a punctured slime filled tire is no simple chore, basically a job for professionals!
   / Screw in front tire, no air leaking, should I worry about it? #14
Fingers crossed.
And most of the places that I know of will charge you accordingly. I stopped using it years ago due to the mess it makes. The only exception is when I don't plan to reuse the rim for some reason.
Or in an emergency, such as if I was snowblowing and needed it to get the tractor home. ;)
   / Screw in front tire, no air leaking, should I worry about it? #15
Just a couple of days ago I noticed a screw head on the tread of one the front tires on my truck. To pull or not to pull. I have a really good mushroom plug kit, so I pulled the screw. It turned out to be all of 1/4" long and in the meatiest part of the tread. I guess if you're gonna pick up a screw......
   / Screw in front tire, no air leaking, should I worry about it? #16
I was pumping gas one day and looked down to see a nail stuck in my tire. Drive across the street to the tire shop thinking they would dismount, plug/patch and get me on my way.
Ended up yanking most of a several y corroded framing nail out of my lug, was stuck sideways. Got **** Lucky.
Currently have a couple roofing/panel nails stuck in the tractor as a result of demo work. Leaving them there as the air seems fine.
   / Screw in front tire, no air leaking, should I worry about it? #17
I never leave anything stuck in a tire. I'd rather address it on my terms in the shop on concrete than somewhere on the road or in the timber. :)
   / Screw in front tire, no air leaking, should I worry about it? #18
I dont leave anything stuck in the tire either, pull it out, check for leak with soapy water, no leak, leave it alone. If it aint broke dont fix it.
   / Screw in front tire, no air leaking, should I worry about it? #19
My dad had a slow leak in his tire so he pulled a nail out, then he had a fast leak. He put some glue on the nail, inserted it back into the hole, and drove to town to have it fixed. I believe he bought a new set.
   / Screw in front tire, no air leaking, should I worry about it? #20
I’ve got screws in low pressure tires that I put there on purpose to plug a hole. I’ve got at least 3 screws in tires between my vehicles and none of them leak so I don’t bother fixing them.
2016 Ford Taurus Sedan (A56859)
2016 Ford Taurus...
Old Compressor With Fork Extensions (A55272)
Old Compressor...
Dump Truck Salt Spreader (A55272)
Dump Truck Salt...
Tank Only (A59076)
Tank Only (A59076)
2019 Ford Transit 250 Cargo Van (A56858)
2019 Ford Transit...
2013 NISSAN NV3500 CARGO VAN (A59575)
2013 NISSAN NV3500...
