Locking threads
/ Locking threads
Sometimes I’ll bugger up the treads on the part that’s through the nut so it can’t back off.
Thread drift story time.....
Years ago I was helping and elderly gentleman change the cutting edges on the grader he ran. They are heavy and his old grader didn't have the ability to rotate the moldboard outside the grader so they had to be changed laying on the ground. When we got the new ones on and the bolts tight he grabbed a ball peen hammer and started beating on the exposed bolt threads. I asked why? He said so they don't come loose. I asked, doesn't that make them hard to remove when you need to rotate the cutters? He looked at me like I was an idiot. Then said, who rotates cutters??? :confused3:
I rotate mine at least 10 times before I have them worn out. :D
/ Locking threads #52
I thought the punch line would be “that is what a torch is for”. :)
/ Locking threads #57
And just above you was this Signature of "Dragoneggs";
The more you know... the more you know you don't know!
For me, seeing that after perusng your link was rather timely.
Speaking of locked threads... for a while I was taking old equipment apart which had been sitting in the woods for decades. I was amazed at how easily those old pre-recycled metal nuts still turn off.
/ Locking threads #58
Speaking of locked threads... .
I ran a #10 drywall type screw into a Locust stump. Three years later when I tried to get it out, it broke off. I cut below the bolt and put it on the wood splitter. Even after I split to expose the length of the screw, it was still tough to get loose.
/ Locking threads #59
I just tighten my vise grips up and clamp down on the exposed threads, those nuts will not vibrate off.
/ Locking threads
I like where this thread has went.
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
MACK AUTOMATIC TRANSMISSION (A60736)
MACK AUTOMATIC...
2022 THOMPSON PUMP 6X6S1 PORTABLE PUMP (A59823)
2022 THOMPSON PUMP...
FORD 6610 TRACTOR (A59823)
FORD 6610 TRACTOR...
2023 Kearney 7'x14' Trailer (A60462)
2023 Kearney...
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
