Cupholder
/ Cupholder #1
def38
woods and mountains of Alabama
M-F 231S
/ Cupholder #3
I took a I think 3” pipe cap drilled 1 hole in the top of the cap, and one hole in the side and a hole through the fender. 1 bolt a nut and split washer ant it is mounted. A bit of foam glued on the inside of the cap and there is my cup holder
/ Cupholder #5
I bolted one of my Frontier booklet holder lids (plastic cylinders with lids) onto the FEL tower of the JD 2025R. It would hold your drink fine.
Ralph
/ Cupholder #6
LX2610 cup holder.jpg I had this on my B2630.
/ Cupholder #7
Clamp this on the fender
/ Cupholder #8
The cup holder on my eMax is so tiny, I wouldn't trust it to hold a 4 oz juice glass. I will be watching this thread for ideas....the plunger might work.LOL
/ Cupholder #9
Years ago, (on this site), someone came up with a simple solution ....if you had steel fenders.
They bought some kind of "big gulp" cup and took some computer hard drive magnets. They epoxied the magnets to the bottom of the cup and now, it's free to stick directly to your fender.
If you have plastic fenders, you can still do this but you have to hold it. :drink:
/ Cupholder
Here in Dixieland, a hard drive is when you get your rear wheels buried in mud after a rain. Also, there is no plastic on my M-F.
/ Cupholder #14
/ Cupholder #15
Ah, yes - the famous and long-running "Chalkey Cup" thread!!
/ Cupholder
Many years ago I bought something called a 'stuckcup' - likely I still have it somewhere. It was a metal insulated cup (about 16 oz) with a strong magnet built into the bottom. It really stuck to the tractor (tho I had a flat rear fender). I looked for those again for you but could not find them.
But did find these - I also have one of these on my tractor:
Amazon.com: Master Magnetics Magnetic Cup Caddy Holder - Black - Keep Your Favorite Beverage at Hand: Automotive
Magnets in the bottom of the SS drink cup I have already...brilliant. I have a dozen neodymium magnets and a new pack of JB Weld...time to get busy and make my own cup. It will rest on the battery cover just in front of the steering wheel. Thanks for all the suggestions but beowulf gets the nod.
/ Cupholder #17
I remember that thread. I have plastic fenders, but liked the idea so much, I was tempted to epoxy a metal plate to them as an attachment point for the Chalkley Cup. Invented by member MChalkley. If you do a search on "Chalkley Cup" in the thread titles, you'll find a lot of hits from the early 2000s time frame.
(BTW, you left one of the "L"s out of Chalkley)
/ Cupholder #18
2021 Jayco Jay Flight 32BHS Camper (A62613)
2021 Jayco Jay...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
40ft Six Section Heavy Duty Metal Storage Shelf (A64047)
40ft Six Section...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
2017 Grand Design RV Toy Hauler Camper VIN # 573FS4334H1108024 (A61166)
2017 Grand Design...
