Anyone own a small portable sawmill? advice on buying one please
   / Anyone own a small portable sawmill? advice on buying one please #11
Biggest thing I have against Woodland Mills BSM, is it's a chinese copy of a Norwood Lumbermate!
I just get sick of the chinese copying everything!
SR
   / Anyone own a small portable sawmill? advice on buying one please #12
And the Norwood Frontier line is a chinese copy of the Woodland Mills chinese copy of the Lumbermate? Nonetheless if I could have afforded more $ for a mill, it probably would have been a Norwood HD 36 with the ability to add hydraulics later. Almost pulled the trigger for one at an Ag show once.
   / Anyone own a small portable sawmill? advice on buying one please #13
I bought the Harbor Freight unit on sale last year.
Not bad for the low priced entry model.
It is ONE HECK OF A LOT OF LABOR especially working by myself. Positioning the log, rolling it, even removing the cut boards and slabs. A 12+ inch x2" green board is heavy. And, of course, the lumber needs to be seasoned for most uses.
The HF saw is limited to 9' logs. They do not sell extensions. I could replace the rails with longer ones but those 9' logs are hard enough to handle.
Ken
   / Anyone own a small portable sawmill? advice on buying one please #14
I'm milling mostly dead Ash on my property for my own uses and am pleased with it so far.
Dave,
any problems using the dead ash? I have milled some, with small holes in it. IDK if it is safe to use the wood for inside projects, I'm afraid of the bugs hatching!
Ken
   / Anyone own a small portable sawmill? advice on buying one please #16
Ken
This is why there is no way I'd own a sawmill without a tractor and grapple.
   / Anyone own a small portable sawmill? advice on buying one please #17
Dave,
Ken
Ash are dying because of Emerald Ash Borers. They destroy parts of the tree at the bark level- they don't make small holes, you can see their damage between the bark and the outer part of the wood. Small holes are likely powder post beetle grubs which invade after the tree is dead. The must be eliminated by kiln drying or treatment (spraying) with a borate product prior to actually using the wood.
   / Anyone own a small portable sawmill? advice on buying one please #19
aaaaawwww NO, Norwood has the "original", they don't need to copy the commies!
SR
   / Anyone own a small portable sawmill? advice on buying one please #20
Let's narrow the search to only "Made in USA"... then filter out all which are over $3K. From those, how many will saw a 16 foot or longer log?
2012 CHEVROLET SILVERADO 2500HD (A50854)
2012 CHEVROLET...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
80in HD Tooth Bucket with Side Cutters (A52128)
80in HD Tooth...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
Toro Z Master Mower (A50322)
Toro Z Master...
