Good morning!!!!
   / Good morning!!!! #118,681
RNG:
Relief valve could be stuck. Turn clock wise all the way. Should always be left in the highest mode so if it fails you can still build pressure. The bolt beside the relief is the strainer it might need to be cleaned. And if it relief is stuck on low side then wd 40 and work the valve.
hope this helps
   / Good morning!!!! #118,682
Good Morning!!!! 69F @ 8:15AM. Partly cloudy skies. Expect widespread areas of smoke and haze, reducing visibility at times. High 91F. Winds light and variable.
This morning's AQI is down to 441, better than yesterday's 600, but still awful.
The ten day is showing daytime highs in the low 90s and mid 80s, with light and variable winds.
The satellite IR map is showing increased activity on Bloomer Mountain, the closest the fire got. There was some mention of back firing operations being used in yesterday's press conference, but I don't know if it's being used there. The coverage of this fire is very poor in terms of keep us informed of where the fire is and what's being done to contain it.
Nice job on the training wheels, Ted. Opens up a whole new world for the grandkid.:thumbsup: With all that dust, you've probably got a partially clogged jet in the mower's carb, and it'll take a stiff bristle or wire to clear it.
Time to get the Red Rider out after that sparrow, Ron.
2550 confirmed CV19 cases in the county, but the health offices are in Oroville and are closed, so they're not updating any of the other info.
Still wearing the N95 mask whenever I'm outside, Don. The air is really nasty out there now. Weatherman said last night we might get some relief next week with the passage of a low pressure system, but then he also mentioned rain that isn't showing in the WU forecast.
You could try changing the WiFi password, Drew. Or get Verizon tech support on the phone and make sure there's not some sort of administrative snafu going on.
If LaNina comes, it'll be a wet winter here. Not good for the burn zones; it means mud slides in the mountains.
I'd thought about the POBox dodge, Jim, and might look farther into it if the Russian connection peters out. Thanks!
There is a Pressure Relief Valve (top row of controls, left end), but it doesn't seem to have any effect, Rick. At most I've seen 45 PSI on the gauge. It's set up to draft water from the 2500 drinking water tank, and the fill valve to the onboard tank is closed. Water is making it out the end of the hose, so the lines are primed, there's just no pressure...
Neat story, Bird. What a life!
Somewhere around here, Paul, I have a pair of safety glasses with bifocals both top and bottom. Very nice when working overhead, very distracting the rest of the time!
Checked with my bodyshop neighbor yesterday morning and found there were no roadblocks or checkpoints on the way to town, so went in and got some fresh vegetables and the fittings needed to install the evap plumbing on the van. The alternator light is still coming on, but the battery is charging, and the voltmeter on the dash is registering a normal 13-14VDC. So depending on how bad the air is out there, I might spend some time on that today.
Hope everyone enjoys their weekend...
What's your intake gauge reading while at 45psi discharge? What gear are you pumping in?
   / Good morning!!!! #118,683
Thanks for the suggestions. Keep 'em comin'!
There are two pressure gauges on the panel, and neither are marked as to what they measure. I've never seen anything but zero on the one on the left, the most I've seen on the one on the right is about 45 PSI.
It's a five speed transmission, and I run the engine at 2000 RPM with the tranny in 5th, which is marked as an overdrive gear. The Waterous instructions say to run the pump with the transmission in the highest gear. I can hear the PTO turning, but I haven't poked my head down there to see it turn, so maybe I'll do that today.
I'll take a look at the pressure relief valve, and review the operating instructions in the Waterous docs. I asked the PO about it, and he doesn't remember ever "messing" (his word) with the pressure relief valve.
I'm not using the on board water tank anymore, mainly because I'm worried that there is still debris in the lines that run between the tank and the pump. No real way to flush them that I can see.
   / Good morning!!!! #118,684
Ok. So you're in the right gear. The gauge on the left should be your intake/vacuum gauge. The one on the right is your discharge/pressure gauge. 2000 rpm and still only showing 45psi? What is your intake gauge reading prior to opening a discharge to flow water? Is it at zero or above? Does it fall lower when you open a discharge?
the pressure relief valve is a wheel, first off, crank it all the way counter clockwise. This is the lowest setting. Then, crank it about 16 turns clockwise. This should put you above 100psi at least. Then should be a short teardrop lever under the wheel. Work it back and forth, then leave the tail pointing to the right. This should be closed. There should also be a round knurled knob under the wheel. Screw that out counter clock wise. It is the screen for the pressure relief valve. Make sure it's clean and re install.
   / Good morning!!!! #118,685
Whoops, Drew beat me to the relief valve info. Sorry, didn't see it prior to posting.
   / Good morning!!!! #118,686
yeah, but I didn't know what I was talking about...;)
It's been over 25 years since I ran a pumper and only did it for two years.
   / Good morning!!!! #118,687
Tried my brush grabber. Didn’t work on small trees, just stripped right up the tree.
Started removing wire from the fence area. Got most of it removed and rolled up. Got too tired and stopped with 1 side to go.
9 yrs ago my oldest sister died.
   / Good morning!!!! #118,688
Just picked load of tomatoes, some corn, 2 green peppers that not sure if ready. Gonna be grilling a couple of steaks seasoned with Yoshida sauce.
Brotherhood
   / Good morning!!!! #118,689
Roy.
Thomas, you have a snow blower for your tractor?
Mrs. has drop couple hints while ago rather we didn't purchase blower for now,and for her to learn plowing with pickup.
   / Good morning!!!! #118,690
wngsprd.
Thomas, 42F?...sounds like pre-snow weather. :)
Temp felt good :) Buppies forecasting has yet been that far off over the years.
Lot 252- LINCOLN MARINE STYLE WELDER SHIELD ARC SAE-400, DIESEL, HOURS SHOWING: 2,937 (A59213)
Lot 252- LINCOLN...
SD Lanch SDLD25 Rubber Track Dumper (A57149)
SD Lanch SDLD25...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A56436)
2-Row Peanut...
2004 Cat 730 Articulating Off-road Dump Truck (A59213)
2004 Cat 730...
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
2018 Kubota SVL95-2S Skid Steer (A57453)
2018 Kubota...
