BX2230D Block Heater
/ BX2230D Block Heater #1
Jveneziano
Kubota
Hey guys I would like to install a block heater in my BX2230D for when I use the snow blower. The dealer says I have to use the inline one for the radiator but I cant see any reason that 70000-00776 will not work? My tractor has a D902-E-BX engine and the BX2350 has a D902-E2-BX-2. I cant really find any differences between the two as to why the block heater would not work?
/ BX2230D Block Heater #2
Not sure about the fit but whatever you do be super careful about drilling in, near, around your block. A few folks have gone thru a bunch of grief by getting into the cylinders. All they were doing was drilling out the freeze plug to add aheater.
/ BX2230D Block Heater #3
Wiser words have never been spoken!
I remember a thread here where the poster did exactly that and it was a very sad story (measured in $$$) to say the least.
My BX2200 has a block heater NOT an in line heater. It was installed by the dealer when I purchased the tractor.
Yea I read that. I think I’m going to stay away from the drill bit method and try and use the punch or a screwdriver and tap it out. Hopefully I can find out if that part number will work.
/ BX2230D Block Heater #6
I also remember some folks were confused as to which freeze plug to put the heater in. If it's a compression fit make sure the edges are clean so it doesn't leak. I put one on in a b2601 and it was a threaded fit. I lucked out!
I just did some Googling and came up with part number 70000-73595. The Coleman Equipment site says it fits the following BX Series:
BX1800D, BX1830D, BX1850D, BX1860, BX1870, BX1880, BX2200D, BX2230D, BX2350D, BX2360, BX2370, BX2380, BX24D, BX25, BX2660D, BX2670
I seen that one to but I’m not sure where it would go on a d902 it looks like the element sticks out to far to go on the block. I did some digging and found install instructions for kit 70000-00771 and it specifically lists it to be compatible with a bx2230. On Messicks website 70000-00771 is no longer available and has been replaced with 70000-00776. So I’m like 99 percent sure that one will work now.
/ BX2230D Block Heater #8
We had an in-line one on our Benz 220D. Worked fine on a -22F morning in Vermont, turned on about 20 minutes or so before starting. Started up that usual 1/2 turn of the crankshaft.
Had a freeze plug one on the Benz 240D. It was used sometimes to provide immediate heat from garage starts but never got a real challenge because we'd sold the Vermont house by that time.
Just need about 20 minutes before starting them. Otherwise, you're just wasting electrical energy with heat going out to the air via the radiator.
Ralph
/ BX2230D Block Heater #9
My BX2230 has a block heater when I purchased it used from a dealer. When cold weather came it was not working. So the dealer put in another one, not sure of the aprt number. But this was about 5 years ago. Dad's BX2230 also has a block heater and his works. Again a used tractor. Jon
Do you happen to have a picture of it installed?
/ BX2230D Block Heater #11
I used to be in the British Fire Service, and many of them had a heater fitted in the bottom hose going from the engine to the radiator. I was with the mechanic once when he fitted one. Drain the fluid, cut through the bottom hose, he used a hacksaw, another cut to leave a gap of about 1 1/2 inches. Pushed in the new heater, two Jubilee clips. Fill up the fluid. He then took the wiring to just behind the drivers seat so a driver couldn't get the door shut without taking out the plug. These heaters were left plugged in all winter. But I have no idea where you can get these heaters or how much the cost.
/ BX2230D Block Heater #12
The depth of room for a block heater may be an issue. The inline heaters work just as well as the in block heaters.
/ BX2230D Block Heater #13
Block heater is on left side of engine when seated on tractor.
let's see if picture posts. Jon
edit. 3 wire power cord strapped to plastic cover goes to red end of block heater.
/ BX2230D Block Heater #14
Exactly what mine looks like. Dealer installed because I didn't want it to leak (not a lack of skill, but a lack of confidence IN my skill :laughing:). Been using it for about 5 years now, insulated garage, but not heated. At 20 degrees inside (-20 outside), it starts like it is 70 outside. A lot less knocking also.
Case IH 181 Rotary Hoe (A66408)
Case IH 181 Rotary...
New/Unused Wolverine Quick Attach Quick Coupler (A65583)
New/Unused...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
Cedar Swing (A65583)
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2016 CATERPILLAR...
